Old 08-28-2010, 03:05 PM
Rare440's Avatar
Rare440 Rare440 is offline
Trim Level: R/T
Rare440 is on a distinguished road
Default 2010 Dodge Ram Air Conditioner Question
Hi everyone,
I'm hoping someone can answer this a/c question for me. The a/c in my new Ram works fine; however, when I push the button to turn the a/c off, nothing seems to happen. The compressor continues to run. Doesn't this system allow for use of only the fan - or is the compressor alway on? I thought that when the button was depressed, the light should go off to signal that the a/c was no longer engaged. Has anyone else experienced this? Thanks for your help!
Old 08-28-2010, 03:19 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Couple of things.
1. There are 2 buttons to push, one for recirc and the other for normal. To turn it off you have to push both.
2. If the light on the left button is on after you push it, you have to make sure the temp is not set to "max".
Brian:
Old 08-28-2010, 03:29 PM
Rare440's Avatar
Trim Level: R/T
Default Thank you!
Thank you for the clarification! I was beginning to think that something was wrong with my new truck.
Old 08-28-2010, 10:30 PM
Flaminchiten Flaminchiten is offline
Vehicle: 2010 Ram 1500
Rep:42
Flaminchiten is on a distinguished road
Also I believe it is always on while in defrost mode, this is pretty standard among newer cars.
a/c, dodge, operation, ram
