trans jumping between gears - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-29-2010, 10:11 AM
moparORnocar's Avatar
moparORnocar moparORnocar is offline
Vehicle: 1997 dodge ram 1500 4x4
Trim Level: SLT Laramie
Color: red
moparORnocar is on a distinguished road
Default trans jumping between gears
my 97 ram with 194,xxx has been expericing some trans problems. it started with slipping and a hard bang when shifting into drive and shifting through the gears. the bang ended up being the universals which i changed and a lucas to the fluid helped the slipping, but now when lite throttle applied (35 to 40 MPH) when shifting it will bounce back and forth from gears untill i really give it some in which case it stays in the lower gear to redline then shifts and all is fine. i was told i could adjust the clutch bands and that may help but i have liitle to no knowhow as far as transmissions go. can any one help me?
Old 08-29-2010, 11:42 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
With high mileage vehicles having tranny issues the first things I go after are fluid and filter.
When was the last time the filter was changed and the fluid completely flush, not just drained and filled?
After that, it is beyond my ability to help.
Brian:
Old 08-29-2010, 11:55 AM
I agree with Brian. A good drain, flush and fill with a new filter first. Since the most effective way to do this is with the pan off, there might be an opportunity to inspect the trans a bit to make sure nothing is obviously broken.
Old 08-29-2010, 03:42 PM
Color: red
i changed the filter a little over a year ago. didnt get it flushed though
Old 08-29-2010, 05:37 PM
Color: RootBeer
Rep:1287
Problem with doing it like that is the fluid is "drained", but it doesn't get all of the old stuff out. Flushing gets it all.
When you changed the fluid, how did it look, red or brown? There's usually a magnet attached to the pan, how did it look?
Brian:
Old 08-30-2010, 09:21 AM
Color: red
the magnet was there and faily clean no shavings or anything like that. The fluid was slighty brown but prior to the draining I had a leak from the trans cooler line so new fluid had been added.
