Cummins factory harmonic balancer verses fluid dampeners Good idea ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 08-29-2010, 05:19 PM
BenShelton BenShelton is offline
Vehicle: 2004 2500 Crew 4x4 long bed
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
BenShelton is on a distinguished road
Default Cummins factory harmonic balancer verses fluid dampeners Good idea ?
I was hoping someone might have some knowledge or experience with replacing the standard factory harmonic balancer with the new fluid dampeners. Is this $300 - $500 investment for a fluid dampener wise ? Will it truly extend the life of my engine and / or make it run better ?
Mine is a 2004 5.9L but this would seem to apply to most engines.
Thanks.
Old 08-29-2010, 05:25 PM
Resident Technician
Rep:1915
I can't speak from a diesel standpoint but I ran Fluidamper balancers on my race engines and they made the engines much smoother. As for a power increase, I can't say because only one was ran beforehand with a stock balancer and a cam swap was performed at the same time.
Old 08-30-2010, 10:49 AM
inc4203 inc4203 is offline
inc4203 is on a distinguished road
You can try to do a search on youtube. i seen a video on there of a before and after installation of Fluidampr. I cant remember if it was for a diesel application. But WOW, what a differance. Ive seen similiar blogs where many diesel guys say the engine is much smoother after Fluidampr install. Just make sure you get the real Fluidampr. They are made 100% in the USA. There are a lot of cheap knock-offs (chinese, india made), usually spelled fluidamper or fluid filled damper.
Old 08-31-2010, 08:08 PM
Thanks and you are so correct there are some knockoffs and cheep copies out there. I always try to buy USA made and I think I know the one you are talking about but I am still doing some research. Found one called Fluidampr #920301 at KLM Performance also seen the one from Bully Dog.
Thanks again for the information.
Old 09-01-2010, 08:13 AM
You are welcome! U got it! The 920301 is a real Fluidampr as well as the Bully Dog dampers are real. Fluidampr and Bully Dog got together to manufacture the Bully Dog dampers.
Old 09-03-2010, 02:43 PM
Did some searching and the few I found all turned out to be Fluidampr they even had the same part number so I plan on ordering one for KLM Preformance soon. $436 is not that bad of a price and I am wiling to risk $500. From what I have seen on-line I think there is little risk here it seems like a no-brainer if you plan on keeping your truck for a long time. I will update this thread when I make the change but if anyone else has some input please post it. Again thanks inc4203
Old 09-07-2010, 10:29 AM
yw! Def. let us know the differance in engine after install of Fluidampr.
