United Radio
Old 08-22-2010, 05:12 PM
xdodgex24 xdodgex24 is offline
Vehicle: 1997 Dodge ram 1500 4x4
Color: greeen
xdodgex24 is on a distinguished road
Default my 5.2 mod list
Ok i'm on a quest to give my 5.2 more power and better mpg's
Let me know what you guys think
Stage one
DIY intake ($70)
Magnaflow muffler ($70)
port and polish TB (FREE!!)
Stage two
Hughes FI airgap intake manifold kit ($599)
pacesetter LT's ($445)
1.7 rockers (unknown)
B&G Custom tune ($350)
valve springs???
Cam???
let me know what you guys think so far and if you know of any better prices please let me know
1997 RAM 4X4, ECSB, SPORT, 5.2l, 3.55's limited slip, peeling clear coat, cracked dash!
Old 08-22-2010, 05:20 PM
Looks like a start .
Old 08-30-2010, 01:22 AM
RamGirl625's Avatar
RamGirl625 RamGirl625 is offline
Vehicle: 1997 Dodge Ram
RamGirl625 is on a distinguished road
what kind of diy intake you talking about. sounds like a good list.
1997 Ram 1500 5.2L Sport 2wd Ext. Cab Reg. Bed
Old 08-30-2010, 01:34 AM
I push the skinny pedal
Rep:3277
Looks like a good list, but I'd watch for the 1.7 rockers, some people ahve had some issues runnign a ratio that high, the 1.6 still gives a good result without the potential of tapping. Everything else looks great
Kurtis
Old 08-30-2010, 01:52 AM
440ram 440ram is offline
Vehicle: 1988 Dodge LS1 Ram
Rep:36
440ram is on a distinguished road
Look into a good roller cam, they can give more lift with less duration making it more efficient and aloowing more power.
I would like to know more about the setup..ie, what vehicle? weight? tire size? etc.
Alot of these dodges cam with 3.55 gears, if you spend most of your time under 70mph, and have an overdrive transmission look into 4.10 gears at least or even 4.56's. The gear advantage will allow the motor to work less and require less throttle position to keep the truck moving, not to mention the hudge advantage in towing conditions and overall acceloration.
To give you an idea of what 4.56's are like in a truck with 31in tires,..its kinda like any car with 3.73;s and a normal 26in. tire, ....not overgeared at all as long as you have OD.
I would do a good CAI setup that keeps the heat out of the intake, full exhaust with ceramic coated headers to keep the heat in the exhaust and out if the engine bay, hollowed out cats for inspection reasons, and 4.56's or 4.10's depending on tire size.
and as always if your after MPG's weight has a big factor in that as well. 20in. rims are alot heavier then 15's, even if the tire is the same height. A mudd terrain will have more drag at highway speeds vs a similar all terrain. Make sure the truck or bed is not full of un needed trash of supplies.
1988 LS1 Dodge Ram
Old 09-07-2010, 08:22 PM
Color: greeen
my truck is a ecsb 4x4 with the stock wheels and tire size running 3.55 gears, I really want to put some 4.10's but its kinda pricey with it being 4x4. I plan on fabing up my own CAI i have done some fiberglass work in the past so we will see how that turns out. thanks for the info on the 1.6 rockers! any idea of the duration of cam would work well with little or no stall?
Old 09-07-2010, 08:24 PM
Color: greeen
I plan on making the top cab out of fiberglass and probably ABS tubbing wrapped in header tape, i also plan on making some kind of cold air scoop out of fiberglass.
