Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 08-30-2010, 10:57 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Default tow haul
i know with tow haul on firmer shift point... but has anyone put it on to go all the way down the track i dont see how can be bad for motor. Also if you have you see any better results. i would test it but my truck in the mod process
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 08-31-2010, 10:15 PM
Trim Level: st
Color: silver
Rep:68
bump anyone help on this
Old 09-01-2010, 01:22 AM
bkoser bkoser is offline
bkoser is on a distinguished road
I know that putting on the tow mode with the cylinder shut down system the engine will automatically kick all 8 cylinders in and give you a quicker start and the RPM ranges will be longer than normal because the tranny shift pressures will get higher which will allow for more power in each gear. It does not hurt the engine at all it is just another program that the computer runs.
Old 09-01-2010, 01:51 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
One nice thing about using tow/haul when racing, it gives you an extra gear in the shift sequence....2nd prime! This should help your ET a bit.
Tow/haul shift sequence - 1, 2, 2P, 3(dir), 4(OD1).
I haven't ran mine at the track, but have tried both regular mode and tow/haul modes on an 'unofficial' 1/4 mile track (highway) using 'unofficial' timing (stop watch). I have noticed a consistent improvement (~.5sec) using tow/haul.
brad
Interested in one of my mods?
Old 09-01-2010, 01:58 AM
chefred112's Avatar
chefred112 chefred112 is online now
Vehicle: 2005 Dodge Ram
Rep:656
thats all I do when im runnin on the track..tow/haul always on...
Old 09-01-2010, 02:01 AM
chefred112's Avatar
Rep:656
i run tow/haul...1st, 2nd, then 3rd...it doesn't touch 2p at all or tranny blows much sooner..
Old 09-01-2010, 02:10 AM
brad12kx's Avatar
Rep:2581
Interesting.....I wonder if that is a change up in the Gen4 trucks. I'm definitely getting a different shift after 2nd, and it's not direct (3rd). Since I run out of 'track' long before gears/rpms, I have not run WOT through all the gears. Next time I have a lot of road in front, I'll try to document the MPH and RPM at the time of shift to calculate the ratio. If it doesn't equate to 2P, then maybe I'll have to borrow a star scanner to see what it's doing.....if the star scanner gives that info real time.
brad
Old 09-01-2010, 02:14 AM
chefred112's Avatar
Rep:656
what are you runnin down the track? 60 fts? 1/8th time an mph an 1/4 time an mph? it'll give us a lil insight...
Old 09-01-2010, 02:25 AM
brad12kx's Avatar
Rep:2581
As I indicated above, all results are 'unofficial'. I have not been to a real track, just used a deserted highway, with odometer measured 1/4 mile and a hand held stopwatch.
Reg - 15.3 @ 92mph (average of 3 runs)
T/H - 14.8 @ 95mph (average of 3 runs)
brad
