Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 08-30-2010, 12:18 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
* P1875 4WD Low Switch Circuit Electrical
* P1884 TCC Enable/Shift Light Circuit
* P1886 Shift Timing Solenoid
* P1887 TCC Release Switch Circuit
* P1890 ECM Data Input Circuit
* P1890 Throttle Position Signal Input
* P1891 Throttle Position Sensor PWM Signal Low
* P1892 Throttle Position Sensor PWM Signal High
* P1893 Engine Torque Signal Low Voltage
* P1894 Engine Torque Signal High Voltage
* P1895 TCM to ECM Torque Reduction Circuit
* P2008 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit
* P2009 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage
* P2010 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage
* P2066 Fuel Level Sensor 2 Performance
* P2067 Fuel Level Sensor 2 Circuit Low Voltage
* P2068 Fuel Level Sensor 2 Circuit High Voltage
* P2096 or P2098 Post Catalyst Fuel Trim System Low Limit
* P2097 or P2099 Post Catalyst Fuel Trim System High Limit
* P2100 Throttle Actuator Control (TAC) Motor Control Circuit
* P2101 Control Module Throttle Actuator Position Performance
* P2105 Throttle Actuator Control (TAC) System - Forced Engine Shutdown
* P2107 Throttle Actuator Control (TAC) Module Internal Circuit
* P2119 Throttle Closed Position Performance
* P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
* P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
* P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
* P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
* P2135 Throttle Position (TP) Sensor 1-2 Correlation
* P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation
* P2176 Minimum Throttle Position Not Learned
* P2500 Generator L-Terminal Circuit Low Voltage
* P2501 Generator L-Terminal Circuit High Voltage
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 06-08-2011, 10:37 PM
jtownes14 jtownes14 is offline
Vehicle: 2004 Dodge Ram 3500 Crew Cab
jtownes14 is on a distinguished road
Wow.... Thanks!
Old 12-09-2011, 09:15 PM
cjk911 cjk911 is offline
Vehicle: 2011 Ram 1500
cjk911 is on a distinguished road
Great info, but I can't seem to get the codes from my 2011 using the described method. Is there a different way to do it without the OBD scanner?
Old 09-24-2012, 01:15 PM
Kaufmann2005 Kaufmann2005 is offline
Vehicle: 2003 Ram 1500 Hemi quad cab
Kaufmann2005 is on a distinguished road
Default Kaufmann2005
That must have took forever to type. I'm thankful though! I will put this in my Library for reference.
Old 11-02-2012, 06:08 PM
05-1500 05-1500 is offline
Vehicle: 2005 1500
Color: blue
05-1500 is on a distinguished road
Awesome! Thanks for the info and easy reference.
Old 11-02-2013, 07:07 PM
Trim Level: st
Color: silver
Rep:68
23k views dammm
Old 02-15-2014, 05:16 PM
therealmccoy therealmccoy is offline
Vehicle: 2012 Dodge Ram 1500 Express
Color: Tequila Sunrise
therealmccoy is on a distinguished road
Do not see the code I'm having...P0868
