Old 08-30-2010, 06:14 PM
countryboy77 countryboy77 is offline
Vehicle: 2000 Dodge Ram 1500 Ext cab
countryboy77 is on a distinguished road
Default Dodge rear differential please help
Ok Guys so I have finally started trying to get my 2000 doge on the road. I dropped the old rear end (3.55) and bought a junkyard one. Problem is the new one is a 3.21. Pro's or cons to using this one. Please help me out I am not sure what to do here!
Erik
Old 08-30-2010, 06:17 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Better mpg, better top end, worse acceleration (not a lot going from 3.55 to 3.21), neither are limited slip, neither is great for towing but will do the job.
Brian:
Rep:1845
Fuel economy may increase slightly but pulling power and accelleration will suffer.
Old 08-30-2010, 06:22 PM
It is a work horse. So I am assuming I either want to keep the same ratio as I had or increase it. Thanks for your help. I am glad to have found this site!
Old 08-30-2010, 07:48 PM
Are you 2wd 0r 4x4 ? If your 4x4 you will need to install the same ratio or replace the front diff with whatever you install .
