Old 08-31-2010, 08:42 PM
RAMROD5's Avatar
RAMROD5 RAMROD5 is offline
Vehicle: 2006 Dodge Ram 3500 Dually
Rep:13
RAMROD5 is on a distinguished road
Default abs / hub question 02 1500
i ordered new wheel bearing hubs bc mine are bad pretty much ASSuming that i had 4 wheel abs. well now im thinking i dont beacuse i went under the truck and i didnt see the wires. the hubs look the same abs to non abs minus the harness, can i just hack off the harness and mount them? thanks
2006 Ram 3500 Dually, 5.7 hemi.
Old 08-31-2010, 08:57 PM
I think you'll be ok . I was gonna recommend to ya to get the correct ones due to the ones with ABS being more expensive . But their only about $8.00 more . The specs that I checked between the two bearing assemblys were the same .
Old 08-31-2010, 09:11 PM
RAMROD5's Avatar
Rep:13
awesome man thank you. the ones around here from napa were 175 each after my discount. no way, i got em for 75 each on ebay from dearborn bearing/detroit axle. prices were the same for each but i didnt realize
Old 09-01-2010, 05:20 PM
RAMROD5's Avatar
Rep:13
any other opinions or do we all agree with tom that it should be ok
Old 09-06-2010, 02:59 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
You will be good just hacking the wire off. Keep the sensor though, I'm not 100% on it, but I think you can unscrew the sensor and thread in a zerk to grease the bearings later.
Sure it'll suck, but it'll make you a man
