Old 09-01-2010, 08:38 AM
nitro1965 nitro1965 is offline
Vehicle: 2013 Ram Express 1500 Quad Cab
Trim Level: exspress
Color: cherry pearl red
Rep:27
nitro1965 is on a distinguished road
Default need help, rearend is bineding?
hello,
i was wondering if there is someone out there that can help me with this problem. i have a 2006 ram 1500 5.7 hemi with a 3.92 limited slip rearend. when i first bought my truck i used to get this bineding in the rearend whenever i took off around a corner. well the dealer changed the fluids in rearend and it went away. a year later and 16,000 miles later i started to get this bineding in the rearend whenever i come to a stop and go straight. it is really noticeable when i get off the highway exit ramp and come to a stop and then go you really feel it. what could be going on that would cause the bineding in the rearend when driving straight ?
Old 09-01-2010, 09:01 AM
Rep:1885
Are you 100% sure limited slip additive was put in when the fluid was changed? You could try changing the fluid again and adding 4 ounces of LSD additive and driving it for a couple of days and seeing if it goes away. If not, the rear end will have to come apart.
Old 09-01-2010, 02:06 PM
Rep:27
yes i know they put the addative in there for that purpose. it went away for awhile and gradually it came back but i notice it more when i am a highway for awhile and get off and come to a complete stop and then go i get this bineding sound from the rearend.if i put some more of that addative in there will that help?
Old 09-01-2010, 02:36 PM
Rep:1885
IF youre sure it's already in there, adding more likely won't help.
Old 09-01-2010, 04:42 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
can you give a better description of the sound?
Brian:
Old 09-01-2010, 05:31 PM
Rep:27
its hard to describe but what it sounds like is it feels like as though you had your e break on and you felt that restriction when taking off and you can feel the bineding through the truck.
Old 09-01-2010, 05:47 PM
Color: RootBeer
Rep:1287
Wonder if it might be a carrier bearing or u-joint?
Brian:
Old 09-01-2010, 10:21 PM
Rep:27
someone else mentioned that to me . where are they located and can they be greased?
Old 09-01-2010, 10:28 PM
What is the service interval for the LSD additive? 16K miles seems like a lot and it may be time to add some.
Old 09-02-2010, 03:09 PM
Rep:27
really for a rearend ? are there clutch plates in rearends? that is on a limited slip differential.are other people having the same issue with the bineding in the rearends of there trucks that have same type of rearend. ?
