Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram – 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 09-01-2010, 02:47 PM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Default My trucks flashing a P0420 and a P0442 code
I was comin home from school, and drove through some pretty heavy rain and big puddles. I'm almost home and then my truck starting drivin really rough, like cutting out. So I went straight to Oreillys and ran a code scanner on it, and it was throwing the P0420(Catalyst system efficiency below threshold (bank 1)) and the P0442 code(Evap emission control system leak detected (small leak)). The guy there it was most likely an O2 sensor. Which makes sense, because this has happened before where I went through a large puddle, and ended up replacing the O2 sensor because of the truck running rough. How is it, that whenever I go through large puddles, it ruins my O2 sensor and makes my truck run poorly?
Old 09-01-2010, 04:37 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Because the 02 sensor is in a very hot exhaust pipe and the very cold water hitting it can mess it up.
Brian:
Old 09-01-2010, 04:55 PM
jcasey10's Avatar
Rep:869
I never though of the temp change. Thanks RootBeer!
Old 09-01-2010, 09:24 PM
Resident Technician
Rep:1911
I'm more likely to suspect the B1 converter going bad.
Old 09-01-2010, 09:57 PM
jcasey10's Avatar
Rep:869
What's a B1 converter? I'm replacing the O2 sensor tomorrow, and I'm gonna see if it helps it.
Old 09-05-2010, 11:11 AM
Resident Technician
Rep:1911
B1 is the Bank 1 converter (drivers side). If you're replacing the 1/2 (drivers side downstream) sensor, you should replace the upstream as well.
Old 09-05-2010, 02:47 PM
DaveDees's Avatar
DaveDees DaveDees is offline
Vehicle: 2010 Jeep Patriot
Trim Level: Latitude
Rep:40
DaveDees is on a distinguished road
From the manual:
P0420-CATALYST 1/1 EFFICIENCY
Diagnostic Test
1. ACTIVE DTC
NOTE: A new rear O2 Sensor along with an aging front O2 Sensor may cause the DTC to set. Review the repair history of the vehicle before continuing.
NOTE: If an O2 Sensor DTC set along with the Catalytic Converter Efficiency DTC diagnose the O2 Sensor DTC(s) before continuing.
NOTE: Check for contaminants that may have damaged the O2 Sensor and Catalytic Converter: contaminated fuel, unapproved silicone, oil and coolant, repair necessary.
Ignition on, engine not running.
With a scan tool, read DTCs.
Is the DTC active at this time?
Yes >> Go To 2
No >> Refer to the INTERMITTENT CONDITION Diagnostic Procedure.
Perform the POWERTRAIN VERIFICATION TEST. (Refer to 9 - ENGINE - STANDARD PROCEDURE)
2. VISUALLY INSPECT CATALYTIC CONVERTER
Inspect the Catalytic Converter for the following damage.
Damaged Catalytic Converter, dents or holes.
Severe discoloration caused by overheating the Catalytic Converter.
Catalytic Converter broken internally.
Inspect both ends of the converter, inlet and outlet.
Leaking Catalytic Converter.
Were any problems found?
Yes >> Replace the Catalytic Converter. Repair the condition that may have caused the failure.
No >> Go To 3
9 - 438 ENGINE - ELECTRICAL DIAGNOSTICS DR
3. EXHAUST LEAK
Start the engine.
Inspect the exhaust for leaks between the engine and the 1/1 O2 Sensor.
Inspect the exhaust for leaks between the engine and the 1/2 O2 Sensor.
Turn the ignition off.
If a leak is heard but unable to be located, it may be necessary to use special tool Miller Tool #8404A Evaporative Emissions Leak Detector (EELD) on the exhaust system to find leaks.
Connect the SMOKE supply tip (black hose) to the exhaust cone adapter (if equipped) and place it into the tail pipe.
Set the smoke/air control switch to SMOKE.
Press the remote smoke/air start button.
While still holding the remote smoke/air start button, use the white light (#8404-CLL) to follow the EVAP system path, and look for the source of the leak indicated by exiting smoke.
If a leak is concealed from view, release the remote smoke/air start button, and use the ultraviolet (UV) black light #8404-UVL and the yellow goggles 8404-20 to look for residual traces of dye that is left behind by the smoke.
The exiting smoke deposits a residual fluid that is either bright green or bright yellow in color when viewed with a UV light.
Be sure to check the exhaust manifold to cylinder head connection for leaks.
Are there any exhaust leaks?
Yes >> Repair or replace the leaking exhaust parts as necessary.
No >> Go To 4
4. ENGINE MECHANICAL
Check the exhaust for excessive smoke caused by an internal problem in the engine.
Is an engine mechanical condition present?
Yes >> Repair the engine mechanical condition as necessary.
No >> Go To 5
5. AGING O2 SENSOR
Review the vehicles repair history.
Has the rear O2 Sensor been replaced without replacing the front O2 Sensor?
Yes >> Replace the Front O2 Sensor as necessary.
No >> Go To 6
6. CATALYTIC CONVERTER
If there are no possible cause remaining, view repair.
Repair
All articles that coruscate with resplendence are not truly auriferous.
Old 09-05-2010, 02:57 PM
DaveDees's Avatar
Rep:40
From the manual, again:
P0442-EVAP PURGE SYSTEM MEDIUM LEAK
Diagnostic Test
1. VEHICLE HISTORY AND SERVICE BULLETIN INVESTIGATION
With a scan tool, read DTCs and record the related Freeze Frame data if any DTCs) are present.
Whether or not any DTCs are present you will want to check the following items which may assist in repairing the customer’s complaint successfully.
Check the vehicles repair history.
If the vehicle has a repair history that pertains to the customer’s current complaint, review the repair.
Inspect the vehicle for any aftermarket accessories that may have been installed incorrectly.
Check for any service bulletin(s) related to the customer’s complaint or DTCs.
If a service bulletin applies, follow the instructions per the service bulletin.
Choose the following scenario that best applies.
The service bulletin repaired the customer’s complaint.
Testing complete.
A DTC is present, no service bulletins apply, or the service bulletin didn’t repair the customer’s complaint.
Go To 2.
9 - 456 ENGINE - ELECTRICAL DIAGNOSTICS DR
2. ACTIVE DTC
Yes >> Go To 3.
3. LOOSE OR MISSING FUEL FILL CAP
Inspect the fuel fill cap.
Inspect the cap for any abnormal defects.
Was the cap off, missing, or broken?
Yes >> Properly install the fuel fill cap and proceed to step.
No >> Go To 4.
4. NVLD SERVICE TEST
With the scan tool perform the NVLD Service Test.
Does the NVLD Service Test pass?
Yes >> Test complete.
No >> Go To 5
5. VERIFY EVAPORATIVE EMISSION LEAK
To continue testing you will need Miller Tool #8404A Evaporative Emission Leak Detector (EELD).
WARNING: Keep lit cigarettes, sparks, flames, and other ignition sources away from the test area to prevent
the ignition of explosive gases. Keep the test area well ventilated.
NOTE: The fuel tank should have between 20% and 80% of fuel tank capacity to properly test the Evap system.
Connect the red power lead of the EELD to the battery positive terminal and the black ground lead to battery negative terminal.
Block the vent hose of the canister if using the service port.
Connect shop air to the EELD.
Set the smoke/air control switch to AIR.
Insert the tester’s AIR supply tip (clear hose) into the appropriate calibration orifice on the tester’s control panel (based on DTC leak size).
Position the red flag on the air flow meter so it is aligned with the indicator ball.
When the calibration is complete, release the remote button. The EELD flow meter is now calibrated in liters per minute to the size leak indicated by the DTC set in the PCM.
Install the service port adapter #8404-14 on the vehicle’s service port and block the vent hose of the EVAP Canister (if equipped) or install the #8404-ADP service adaptor into the filter line.
Connect the Air supply hose from the EELD to the service port (if equipped) or to the #8404-ADP adapter.
Press the remote button to activate AIR flow.
NOTE: Larger volume fuel tanks, lower fuel levels or if the vehicle is equipped with a Flow Management Valve may indicate high flow and will require 4 to 5 minutes to fill.
Compare the flow meter indicator ball reading to the red flag.
DR ENGINE - ELECTRICAL DIAGNOSTICS 9 - 457
ABOVE the red flag indicates a leak present.
BELOW the red flag indicates a sealed system.
Is the indicator ball above the red flag?
Yes >> Go To 6.
6. EVAPORATIVE EMISSION LEAK DETECTION
NOTE: A thorough visual inspection of the Evap system hoses, tubes, and connections may save time in your diagnosis. Look for any physical damage or signs of wetness at connections. The strong smell of fuel vapors may also aid diagnosis.
To continue testing, you will need Miller Tool #8404A Evaporative Emissions Leak Detector (EELD).
Remove the Air supply hose from the service port (if equipped) or from the #8404-ADP adapter.
Connect the SMOKE supply tip (black hose) to the service port (if equipped) or to the #8404-ADP adapter.
NOTE: The flow meter indicator ball will not move in the smoke mode.
NOTE: Make sure that smoke has filled the EVAP system by continuing to press the remote smoke/air start button, remove the vehicle fuel cap, and wait for the smoke to exit. Once smoke is indicated reinstall the fuel cap.
NOTE: For optimal performance, introduce smoke into the system for an additional 60 seconds; continue introducing smoke at 15 second intervals, as necessary.
While still holding the remote smoke/air start button, use the white light #8404-CLL to follow the EVAP system path, and look for the source of the leak indicated by exiting smoke.
If a leak is concealed from view (i.e., top of fuel tank), release the remote smoke/air start button, and use the ultraviolet (UV) black light #8404-UVL and the yellow goggles #8404-20 to look for residual traces of dye that is left behind by the smoke.
NOTE: The EVAP System is divided into three zones. A leak from any of these zones can cause this DTC to set. The lists below specify the possible leak points in that specific zone. For further assistance see theZone Identification Charts below.
ZONE 1
1 Fuel Cap
2 Recirculation Check Valve.
3 Vapor Recirculation Line.
4 Signal Vapor Line for FVM.
5 Flow Management Valve.
6 Fuel Tank to Canister Vapor Line connection.
7 Fuel Tank Vent (Check Valve).
8 Vapor Line to Canister.
9 Flow Control Orifice.
10 Control Valve.
11 Liquid Trap.
12 Fuel Tank.
13 Check valve.
14 Fuel Fill Tube to Tank connector.
15 Fuel Fill Tube
Damaged or disconnected EVAP system components.
9 - 458 ENGINE - ELECTRICAL DIAGNOSTICS DR
ZONE 2
1 Filter.
2 NVLD.
3 Canister Vent Line.
4 Evap Canister.
5 Chassis Purge Valve.
7 Evap Purge connection.
ZONE 3
1 Evap Purge Vacuum Line.
2 Connection to Chassis Line.
3 Connection to Canister.
4 Chassis Purge Line.
5 Evap Purge Vacuum Line.
6 Connection to Evap Purge Harness.
7 Chassis Evap Purge Line connection to Engine Vacuum.
8 Evap Purge Valve.
9 Service Port.
NOTE: Carefully inspect the vent side of the EVAP Canister. Due to the filtering system in the canister the smoke may not be as thick.
Introducing smoke into the filtered side of the canister may assist in locating the leak.
Was a leak found?
Yes >> Go To 7.
No >> Go To 8.
7. LEAK AT GAS CAP
Remove the SMOKE supply tip (black hose) from the service port (if equipped) or to the #8404–ADP adapter.
Install gas cap adapter, Miller Tool #8382 (1/4 turn cap) or #6922 (screw cap) and #8399* (secondary seal depressor) and repeat test 5.
Was a leak found at the gas cap adapter?
Yes >> Replace the Fuel Filler tube assembly.
No >> Replace the gas cap.
8. EVAP PURGE SOLENOID OPERATION
NOTE: After disconnecting the Evap Purge Solenoid vacuum connections, inspect the lines and solenoid for any signs of contamination from the EVAP Canister. This may indicate a inoperative check valve. Replace/repair as necessary.
Disconnect the vacuum hoses at the Evap Purge Solenoid.
Press the remote smoke/air start button on the EELD.
While holding the remote smoke/air start button, check to see if smoke is exiting the purge valve. This indicates that there is a leak internal to the purge valve.
NOTE: Below is an optional method of checking the purge valve for leaks if the EELD is unavailable.
Using a hand vacuum pump, apply 10 in HG to the “CAN” of the Evap Purge Solenoid.
NOTE: Monitor the vacuum gauge for at least 15 seconds.
Is smoke visible from the EVAP Purge Solenoid if using the EELD, or not hold a vacuum?
Yes >> Go To 9.
No >> Replace the Evap Purge Solenoid.
9. NVLD SWITCH OPERATION
Reconnect all vacuum hoses.
Start the engine.
Allow the engine to idle.
Using the scan tool, perform the NVLD FORCED MONITOR TEST.
Monitor the NVLD Switch.
NOTE: As the test runs, the NVLD Switch should go from an OPEN state to CLOSED. After the vacuum is released form the EVAP system the Switch state will return to OPEN.
Did the NVLD Switch operate as described above?
Yes >> Refer to the INTERMITTENT CONDITION Diagnostic Procedure. (Refer to 9 - ENGINE - DIAGNOSIS
AND TESTING)
No >> Replace the NVLD Assembly.
Old 09-05-2010, 05:55 PM
jcasey10's Avatar
Rep:869
That's quite the list lol. Thanks for that!
Old 09-05-2010, 09:03 PM
DaveDees's Avatar
Rep:40
You're welcome......just trying to cover all the bases. LOL
