Old 09-02-2010, 10:12 AM
01RamOffRoad's Avatar
01RamOffRoad 01RamOffRoad is offline
Vehicle: 2001 Ram 1500
Trim Level: Sport Off-Road
Rep:17
01RamOffRoad is on a distinguished road
Default Interior Lights
All my interior lights have stopped working. The 2 in the console up front on the roof and my dome light in the back. Any easy fix for this? Truck is a 2001 Ram Sport.
Old 09-04-2010, 01:21 AM
Rep:1625
Old 09-04-2010, 01:35 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
What position is the master switch in? Check the fuses.
Brian:
Old 09-04-2010, 12:30 PM
Check all the fuses in both locations first . Let us know .
Old 09-10-2010, 11:59 AM
Dtimekw Dtimekw is offline
Vehicle: 2001 Ram
Color: Blue
Rep:23
Dtimekw is on a distinguished road
Did you find out what the problem was?
01 Ram Sport, 5.9, Body/Suspension lift on 36's, 4wd
Old 09-27-2010, 01:36 PM
RamRunner4x4's Avatar
RamRunner4x4 RamRunner4x4 is offline
Vehicle: 1998 dodge ram 1500
RamRunner4x4 is on a distinguished road
I have this same problem, all fuses r fine and I replaced any that looked the slightest bad and still nothing works not even my display on thr roof that shows temperature and direction. Also my 3rd break light doesn't work at all
If You Aint First, Your Last.
Old 09-30-2010, 07:00 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
did you figure it out?
Old 10-08-2010, 12:29 AM
Dennyboy's Avatar
Dennyboy Dennyboy is offline
Vehicle: 1999 regular short box sport
Rep:140
Dennyboy will become famous soon enoughDennyboy will become famous soon enough
you need to break out the multi meter and start testing. ide first check and make sure your getting voltage to the switch and then after the switch. you can also pull the switch apart and check for bad connections.
as for teh third break light test power and grounds.
Dakota County Technical college
Auto Tech apprentice
cataclysmic perverter
If you don't stand behind our troops, PLEASE feel free to stand in front of them.
Old 10-24-2010, 10:32 PM
Landis77 Landis77 is offline
Landis77 is on a distinguished road
There is a fuse in the dash block called IOD. It's one of those with a cover on it, like the air bag ones. i replaced it in my 2001 Ram and the radio, interior lights, and power mirrors all are working again. I don't know what it is for, but the IOD circuit was my problem.
Old 10-24-2010, 10:36 PM
Rep:17
Hmm..interesting. I'll have to check that before my mechanic has the part in that he thinks will fix it. He called it a floor switch? I'm not exactly sure where that is located or what is has to do with the interior lights not working.
