Old 09-02-2010, 12:26 PM
TimHague TimHague is offline
TimHague is on a distinguished road
Default Re-setting the Oil Change warning
How do I do it fellas? Just switched over to Mobil 1 and now i cant get the warning light to turn off.
Old 09-02-2010, 12:28 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Turn key to the on position (But don't start engine), then floor gas slowly three times within 10 seconds, then turn key back to off. That should do it.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 09-02-2010, 02:29 PM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
^^^^ right fromt he manual!
DODGE the father RAM the daughter!
Old 09-02-2010, 06:01 PM
moparornocar72's Avatar
Rep:630
Like he said. Alldata has the same thing but added a few more tips:
The vehicle is equipped with an engine oil change indicator system. The "Oil Change Required" message will flash in the instrument cluster odometer for approximately ten seconds after a single chime has sounded to indicate the next scheduled oil change interval. The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate dependent upon your personal driving style.
Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Menu button. To reset the oil change indicator system (after performing the scheduled maintenance) perform the following procedure.
  1. Turn the ignition switch to the ON position (do not start the engine).
  2. Fully depress the accelerator pedal, slowly, three times within ten seconds.
  3. Turn the ignition switch to the LOCK position.
Note: If the indicator message illuminates when you start the engine, the oil change indicator system did not reset. If necessary, repeat these steps.
14.268 @ 95 MPH Full Trim
Old 09-03-2010, 07:00 PM
BeBeep's Avatar
BeBeep BeBeep is offline
Vehicle: 2010 Ram
Trim Level: R/T
Rep:16
BeBeep is on a distinguished road
Great info, I made a note of it. Thanks.
2010 Ram R/T - 2011 GWE Challenger SRT8
Old 09-03-2010, 07:16 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Does anyone know if you can "reprogram" the computer for 5K changes when running synthetic? I can't see a way, but it would be nice.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 09-03-2010, 10:46 PM
Rep:630
Maybe a flash or using obdII readers. I have a MODIS at work, I will one day hopefully next week have 5 minutes at work to plug and play with it. I'll let you know hopefully soon!
Old 09-06-2010, 04:12 PM
Pauliepaul10's Avatar
Pauliepaul10 Pauliepaul10 is offline
Trim Level: SLT HEMI
Color: Brilliant Black jewel tint coat
Pauliepaul10 is on a distinguished road
I asked my dealer about resetting the mileage for a longer lasting synthetic and he said they can do it they just don't like to since you won't be back as often LOL.
Volant CAI, DS Trinity, Flowmaster, Hellbent lev. kit, Bakflip G2, 35/20 tint, BT catch can.
Old 09-06-2010, 11:23 PM
Wildcat's Avatar
Rep:166
This is good news! Now if I can get my dealer to do it for me.
Old 09-06-2010, 11:27 PM
Rep:1890
The dealership person you talked to is wrong in your case. Beginning with the DS body style, the indicator is duty cycle based and is no longer programmable.
