Place your Ad Here!
Closed Thread
Old 08-12-2013, 06:03 PM
InDeepWaterBlue's Avatar
Rep:611
Originally Posted by rider1121 View Post
The 2013 Ram 1500 will only play the radio(8.4) on ACC setting for about 20 minutes. Is there a way to allow it to play until you shut it off, instead of it shutting itself off? It is also a KFOB starter, so only OFF, ACC, and RUN settings.
Not sure, on my 2011 my options are OFF, ACC, RUN, and START. So if I'm tailgating I'll turn the key to RUN and let it go occasionally starting it up to make sure the battery doesn't die on me lol
Old 08-14-2013, 12:53 PM
mcline1968 mcline1968 is offline
Vehicle: 2008 3500 DRW
Color: BLACK
mcline1968 is on a distinguished road
Could you tell me what the actual dimensions of the factory NAV opening are? I have an extra non-nav bezel I am going to try and modify before I shell out $$ on an OEM NAV bezel.
Any pointers would be appreciated as well.
Thanks
  #1003
Old 08-14-2013, 12:55 PM
Color: BLACK
OH BTW, It's a 2008 Truck
  #1004
Old 08-14-2013, 08:36 PM
bigbob15 bigbob15 is offline
Vehicle: 2003 Dodge Ram 1500
bigbob15 is on a distinguished road
Default RCA problems
i have an Alpine iDA-X305S head unit. I tested the RCA plugs and i am getting no signal at all from them. I went and bought new jacks and then tested those too and nothing so i have come to the conclusion that my head unit ports are bad. Is there anything i can do to fix this problem so my subs will work again. Besides hard wiring the subs to the back of the head unit? Or should i buy a new unit? is it common for them to stop working after a few years? please help
  #1005
Old 08-22-2013, 01:24 AM
Mike226's Avatar
Mike226 Mike226 is offline
Vehicle: 2016 Ram
Rep:48
Mike226 is on a distinguished road
I have a 14" antenna on my truck, and thinking about putting in a signal booster for my fm antenna to make it a little better. Any recommendations? And will I need adapters for the connections on stock antenna (like these http://www.installer.com/item/displa...p?it=40-EU30)?
Or would I be better off going with a hidden antenna for better reception than using the stubby?
  #1006
Old 09-10-2013, 08:04 PM
Zxalfiezx Zxalfiezx is offline
Vehicle: 2005 dodge ram 1500 slt
Trim Level: Slt
Zxalfiezx is on a distinguished road
I have an 05 1500 slt QC with the 7 speakers. I want to add a sub woofer and re do all of the internal speakers. Would It be possible to put all 7 speakers to amps or is this impractical? And if it isn't what would be the best set up. 2-3 amps? Or... That's where I get stuck. Thanks
  #1007
Old 09-12-2013, 01:42 PM
danno123 danno123 is offline
Vehicle: 2010 Ram 2500
danno123 is on a distinguished road
Hey Guys,
I need some advice swapping an RER to RHR in a 2010 Ram 2500. The install went fine. All the connections were good. Took to dealer for StarScan but the RHR wasnot listed as an option for my truck. The screen is black and does not function. Lights on the HU light but screen is black. I think I might have a Can Bus issue or a security code issue. Any help would be appreciated.
Thanks
  #1008
Old 09-15-2013, 01:39 PM
HEMIGUY390's Avatar
HEMIGUY390 HEMIGUY390 is offline
Vehicle: 2011 Ram Sport
Trim Level: Sport Crew Cab
HEMIGUY390 is on a distinguished road
Default did you upgrade the sub
Originally Posted by webhair View Post
Hello, I have an 2011 Ram 1500 Sport Crew Cab with the Alpine system... IT sounds ok but is missing the bottom end. Does anyone know of a sub box that will fit the Crew Cab.
I have a friend with a Quad Cab and the area under the rear seat is different. So am I pretty sure one for Quad Cab will not work...
Thanks!
Hi, wondering if you upgraded the sub and what you did. Thanks
  #1009
Old 09-19-2013, 10:38 AM
MurderedOne87's Avatar
MurderedOne87 MurderedOne87 is offline
Vehicle: 2013 Ram 1500 Black Edition
Trim Level: Tradesman/Express
Color: All Black
Rep:70
MurderedOne87 will become famous soon enough
Hey guys,
First post... many many more to come. I have been a premium member on the past two forumz...
I just purchased a 2013 Express Black Edition
It has the ~ 2013 RAM 1500 UCONNECT® 5.0/RA2
I believe it is a non amplified/ basic system. My issue i dont understand why when i go any louder than about 28 it distorts out and its like it is cutting itself back to protect it like my 8.4N alpine system did in my charger.... but that was a a feature built into the ALPINE AMPLIFIER in my charger... My RAM does NOT have a factory amp.
So what my question is... Is it the speakers that are distorting out??? or the headunit keeping the audio levels adjusted to keep from blowing the speakers?? I am going to replace whatever necessary.
My other question is if i add an aftermarket headunit what happens to my uconnect menus built into the OEM radio? what all will be lost?
  #1010
Old 09-25-2013, 10:43 PM
514RAM's Avatar
514RAM 514RAM is offline
Vehicle: 2013 DODGE RAM SPORT QC 4X4
Trim Level: SPORT
Color: BLACK
514RAM is on a distinguished road
Hey all...
I have a Samsung Galaxy S3 and cant figure out how to watch Netflix via my phone on my u connect screen in my '13 dodge ram 500 sport.
Please help!
Closed Thread
