Closed Thread
Old 11-09-2010, 07:02 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Don't worry about the questions, that's what we are here for!
1) You can, I used my own ground "bolt" though for a more secure mount. Used a wire wheel on the grinder to clean a spot, put the ground cable there and screwed in a monster self tapping screw.
2) Does the harness work? I mean does the head unit turn on with the aftermarket harness? Taping off the speaker wires won't be a problem since you are using the Imprint Ai-Net cable. My concern is that the Alpine head unit will turn on using that harness.
3) It will be ok. Just keep an ear out for any humming, but you should be just fine.
4) I'll have to let someone else chime in on the Bluetooth, the MyGig came with it for me.
Old 11-09-2010, 10:02 AM
11HEM1's Avatar
11HEM1 11HEM1 is offline
Vehicle: 2014 Dodge Ram 1500 Crew
Color: PX8- Black Clear Coat
Rep:31
11HEM1 is on a distinguished road
Another question since I didnt get a response on first one. So can I add a say on 2008 radio in my 2004? I understand there will need a new bezel and some mods but will it work?
Debadged -4" Mopar Lift - XD Cranks - 325/60/20 Nitto Grapplers
  #123
Old 11-09-2010, 10:06 AM
11HEM1's Avatar
Rep:31
here are a couple I would like to try
or even this one that was taken out of an 05 ram
  #124
Old 11-09-2010, 10:52 AM
chithead's Avatar
Rep:2078
That I can't really answer. The bus speeds may not match up between 2008 and 2004, providing a major headache if they don't. For the same time and cost involved, you might want to check out an aftermarket head unit instead.
  #125
Old 11-09-2010, 11:10 AM
11HEM1's Avatar
Rep:31
What abou the one out of a 05 ram I looked it up and it says it will fit.
  #126
Old 11-10-2010, 07:01 AM
vonirkinshtine vonirkinshtine is offline
Vehicle: 2005 Dodge Ram 1500
Rep:38
vonirkinshtine is on a distinguished road
Hey guys! So...I just got a 2005 1500 SLT that has this radio in it:
Reading through the owner's manual it says that "mode" button is used to cycle through the optional CD changer or satellite radio. NOW, I don't have any of those things, but I take that to mean that this head unit has the ability to accept "auxiliary" inputs. Is there a way I can tap into that ability and add a 1/8" stereo plug for connection of an MP3 player?
I know it would probably be easier to just add an aftermarket head unit, but I love keeping the "stock" look. If I can keep the stock head unit but add the ability to play back from an MP3 player, I would be a happy camper :-)
  #127
Old 11-10-2010, 07:20 PM
ram8923 ram8923 is offline
ram8923 is on a distinguished road
im sure this has been answered before although i cant find a clear answer. im pulling my pioneer headunit from car and putting it in my brothers 2004 1500 quad cab with infinity audio without uconnect. now i know that i need the dash kit and antenna adapter, but what wiring harness do i need?
Is this the right one because im not really sure what amp bypass means im only changing the headunit to aftermarket i would like to keep the infinity speakers and amp?
metra 706512
http://www.sonicelectronix.com/item_...FRZy5QodEhpfHw
  #128
Old 11-10-2010, 11:18 PM
chithead's Avatar
Rep:2078
That harness is to be used with an aftermarket amp ^^^
  #129
Old 11-10-2010, 11:49 PM
Ok thanks. i was pretty sure i need to integrate the amp into the system not bypass. Since that one is the wrong one, then what harness do i need?
am i right with this one?
http://www.crutchfield.com/S-sdH6RwB...Interface.html
and if that is the one is that the only one or is there a cheaper one?
Thanks
  #130
Old 11-11-2010, 12:04 AM
chithead's Avatar
Rep:2078
I believe that is the correct one, but WOW that price!!!
Closed Thread
