Have Audio Questions? We've Got Answers! - Page 18 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Closed Thread
Old 12-03-2010, 01:35 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
You can wire a switch to that wire and then just ground it... that way if you get inspected or anything you can just flip the switch and it functions legally... but you didn't hear that from me.
Old 12-03-2010, 01:25 PM
webhair webhair is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport - Crew Cab
Rep:30
webhair is on a distinguished road
Hello, I have an 2011 Ram 1500 Sport Crew Cab with the Alpine system... IT sounds ok but is missing the bottom end. Does anyone know of a sub box that will fit the Crew Cab.
I have a friend with a Quad Cab and the area under the rear seat is different. So am I pretty sure one for Quad Cab will not work...
Thanks!
  #173
Old 12-03-2010, 07:12 PM
drivehard27's Avatar
drivehard27 drivehard27 is offline
Vehicle: 2014 dodge ram
Color: Maroon
Rep:108
drivehard27 will become famous soon enoughdrivehard27 will become famous soon enough
Send a message via Yahoo to drivehard27
thanks daniel i will do that wife will be happy
  #174
Old 12-03-2010, 07:46 PM
imdunworkin imdunworkin is offline
Vehicle: 2008 Dodge Ram 6.7 Liter Diese
Color: Tan
imdunworkin is on a distinguished road
I have a 2008 Ram 2500 with the upgraded sound package. Speaker in right front passenger door keeps cutting out. Any suggestions?
  #175
Old 12-03-2010, 10:47 PM
DoubleARS DoubleARS is offline
Vehicle: 2005 Dodge Ram
Trim Level: Daytona Edition #363
Rep:24
DoubleARS is on a distinguished road
Default Amp Setting Help
I finally fired up my truc today after doing a big install of stuff. Tomorrow I am going to run the Alpine IMPRINT software but I want to make sure my amp is set right first and the manual has me confused.
Alpine PDX-5
Channel 1/2 Front door speakers - Alpine SPR-69C
Channel 3/4 Rear door speakers - Alpine SPR-17C
Sub - JL Audio Stealthbox with 10" sub
Questions:
Channel 1/2 & 3/4 have switch with 3 positions - OFF, LP, and HP. What should they be set at?
Channel 1/2 & 3/4 have a dial for gain and one for crossover. How do I set them?
Sub has a dial for gain and one for LP filter. How do I set it?
Thanks
  #176
Old 12-04-2010, 08:04 AM
Rep:30
I am sure some one will answer this that has more knowledge then I do. But from what I do know...
Channel 1/2 & 3/4 I would set them to LP, The crossover is to determine at what frequency the crossover occurs between the mid range and the low. This should cut out the really low frequencies. The gain is relative to the volume adjustment. (Do not over power the speakers). Use it to adjust a balance between the speakers.
Turn on the LP filter for the sub - it will stop the higher frequencies from going to the sub.
Now hopefully some with more knowledge then I will correct my understandings...
What year truck are you putting this system in?
By the way - Sounds like a great system.
  #177
Old 12-04-2010, 09:36 AM
chithead's Avatar
Rep:2078
I still give you reps for helping out, but it's actually the other way around.
A high-pass filter passes frequencies above a pre-determined frequency and attenuates those below. A low-pass filter passes frequencies below the crossover point and attenuates (blocks) those above.
The setting should be to HP, maybe start around 90Hz and see how your mids handle that first, then slowly turn the number higher until you don't hear any distortion.
The gain settings are a bit trickier. It's best to have an empty parking lot for these settings. Typically you would set them as low as possible. Crank the volume knob to a reasonably loud level and listen for distortion. All still clear? Then start turning the gain knobs up. Once you start to hear nastiness, turn them back down until they clear up again.
  #178
chithead's Avatar
Rep:2078
Sounds like the speaker is failing. Time to upgrade!!!
  #179
Old 12-04-2010, 07:45 PM
veilofmaya7's Avatar
veilofmaya7 veilofmaya7 is offline
Vehicle: 2010 1500 QC 4X4
Trim Level: SPORT
veilofmaya7 is on a distinguished road
Send a message via AIM to veilofmaya7
Default Thinking about replacing my 8 in sub in my 10 ram quad hemi sport
i was thinking about replacing the stock 8 in alpine sub with a 8 in jl and was just wondering if the stock sub would be able to handle it or would it just be better to do a custom box underneath the rear seat even though there is limited space for mounting bigger subs
  #180
Old 12-05-2010, 09:36 AM
Rep:30
I was wondering about that - thanks for clearing it up for me!
Closed Thread
