Closed Thread
Old 12-15-2010, 12:38 AM
ccga3359 ccga3359 is offline
Vehicle: 2005 Dodge Ram 1500
Color: Atlantic Blue
Rep:42
ccga3359 is on a distinguished road
What componants do I need to add ipod to my '05 RBQ radio. Does Dodge sell the kit or do I go aftermarket? Is this setup FM based? I currently have something like that and I keep losing ipod when I drive into a stronger radio signal.
Grant
No matter how much you push the envelope, it's still stationary.
Old 12-18-2010, 12:01 PM
ktm318 ktm318 is offline
Vehicle: 2010 Dodge Ram 1500 4x4
ktm318 is on a distinguished road
Hey guys I am new here and I have a question... I have the alpine system and I wanted to get just a little more out of it so I installed an LC8
  #203
Old 12-18-2010, 12:16 PM
sorry I don't know what just happened, any way I installed the LC8 to the out put of the factory amp, i installed a JL HD750 driving 2 JL 10W3v3's, a JL HD600/4 driving a pair of Focal K2 power components up front and a pair of Focal access coax in the rear. I just cant seem to get things to sound the way they should so I want to install my Kenwood DNX5120. I know I need a couple of pac modules to hook everything up including the stearing wheel controls but I havent been able to find anything about how to wire the back up camera. Also should I remove the lc8 and bypass the factory amp or will the pac module allow me to use it and increase the power to the amps since the 5120 is a bit uner powered?
  #204
Old 12-18-2010, 12:38 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I would. It would make wiring everything up so much easier. You could still retain the LC8 since you have it, but bypassing the factory amp is definitely a great idea.
  #205
Old 12-18-2010, 04:39 PM
Yeah thats what I was thinking too. Any experiance with the back up camera? I havent pulled the head unit out yet to see whats up...i was hoping to know up front if it will even work or if I needed anything to connect things up before i started and couldnt finish.
  #206
Old 12-18-2010, 09:48 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
This may work or call Pac-Audio to see what they recommend for that particular radio
http://www.pac-audio.com/productDeta...&CategoryID=36
  #207
Old 12-19-2010, 01:11 AM
Dustinmc15 Dustinmc15 is offline
Rep:73
Dustinmc15 will become famous soon enough
Ok guys, I'm a noob when it comes to car audio so I need some help with wiring my system. I have 2 10 inch DVC 4 ohm subs and a 2 channel amplifier with a thunderform enclosure. The enclosure only has 1 terminal cup, what is the best way to wire this up? Thanks for any advice.
  #208
Old 12-19-2010, 01:45 AM
67Polara's Avatar
67Polara 67Polara is offline
Vehicle: 2001 2500 ext cab long bed
Trim Level: sport
Rep:77
67Polara will become famous soon enough
killed my stock speakers, anyone know what would be the best bang for the buck for a pretty decent set, really looking for somthing that can handle good bass for techno, but still sounds good with rock.
"I'm your huckleberry" (Doc Holiday)
  #209
Old 12-19-2010, 01:51 AM
Trim Level: Custom
Rep:1648
Look at the third diagram....
  #210
Old 12-19-2010, 01:52 AM
Trim Level: Custom
Rep:1648
I need a bit more info....What headunit do you have? Infinity system? Any amps?
Closed Thread
