Closed Thread
Old 12-30-2010, 01:51 AM
blazer blazer is offline
Vehicle: 1999 dodge ram
blazer is on a distinguished road
Originally Posted by chithead View Post
I'd have to research more into this.
Thanks chithead,but i got it figured out today,i finally found which two speaker wires feed into the old amp and which two feed out to the back speakers.I got it all hooked up today and the clarion and Jbl's sound really great.now i need to get me a good subwoofer and amp.im thinking about just adding a amp to push the sub and having the ph push the 4 door speakers.does anyone know if this would work out good or do i need to add a amp to the jbl's also.
thanks in advance
Old 12-30-2010, 02:31 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
A four channel amp would allow you to amplify the JBLs, then you bridge two channels to power one subwoofer. Just make sure the subwoofer has a 4-ohm voice coil.
  #263
Old 12-30-2010, 04:15 PM
BBRam BBRam is offline
Vehicle: 2011 Dodge Ram
Trim Level: QC Laramie
BBRam is on a distinguished road
Thanks chithead and dodgeman70592 (and everyone else) for this great thread. Lots of good info here.
Does anyone know what the crossover frequencies are in the Alpine system? I assume none of the outputs are full range??
Debadged, Rhino Liner, stubby ant, Gorilla BC lugz, caf
  #264
Old 12-30-2010, 04:30 PM
chithead's Avatar
Rep:2078
Thats correct! Best I can tell they are 1200hz and down on the front doors, 125hz and up on the rears, with a mid boost and high frequency eq cut, and the dash are 150hz and up, with a high frequency boost and midrange cut.
  #265
Old 12-30-2010, 10:53 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
When buying a sealed box for a subwoofer, should you stay towards the higher end of the airspace required of the lower end for the air space requiremt?
  #266
Old 12-31-2010, 07:39 AM
chithead's Avatar
Rep:2078
Higher end will let it play lower. If you go towards the lower end, you can stuff polyfill in to add a little bit more bottom to it. General rule is 1lb. of polyfill for every 1cu.ft. of volume.
  #267
Old 12-31-2010, 09:17 AM
Thanks Daniel
  #268
Old 12-31-2010, 11:12 AM
chithead's Avatar
Rep:2078
Anytime! Thank you sir!
  #269
Old 01-02-2011, 04:02 AM
chad3113 chad3113 is offline
Vehicle: 2013 Dodge Ram 1500
chad3113 is on a distinguished road
OK Guys, I've searched and couldn't find an answer. What is the easiest way to replace the factory Alpine Sub? I have a 2010 Ram with the 10 speaker Alpine system, and the bass is TERRIBLE!!
All I want is a 10'' Sub in a custom box to replace the factory garbage. Mids, highs, and touchscreen will all remain the same.
Also, feel free to offer suggestions as to what amp/sub combo to use...
I'll have my local shop doing the install, but I want some sense of direction from you guys before I go to them clueless
  #270
Old 01-02-2011, 04:17 AM
MADDOG MADDOG is offline
Rep:22
I'd give JL subs and amps a serious look chad3113. There are cheaper ones out there (kicker, MTX, etc...) but JL really makes some great stuff at a good price.
Closed Thread
