Place your Ad Here!
Closed Thread
Old 01-08-2011, 09:08 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Originally Posted by Drparj View Post
Ok I read through all 29 pages here and nothing on what I need. This is not my first adventure into audio and honestly do wiring fairly easy. However I have never toyed with a can bus system and with also keeping the steering wheel controls.
I have a 2010 crew cab 1500. I have the basic 6 speaker package with no amps.
I am looking to simply replace the head unit with aftermarket and keep steering wheel controls.
I already have all three pac controllers I need.
CRY4, swi ps and swi can2.
I have all the wiring schematics on these there items and think I have it worked out. My question is it either looks to easy or I don't want to screw it up. Are these three boxes easy to install and make everything work. Is there a breakdown somewhere that someone has done on installing all three pac boxes, I think wiring main one is fairly forward but gets confusing adding the 2 others in.
Wiring schematics from pac not needed as I have all them already, some insight or actually pictures of these wired in would be great. At least if I saw a picture with all three wired in it could tell me alot.
Thanks Guys
Normally, every Pac-audio piece is quite straightforward and will work really well. I have installed many, I just have no pics to share. If it were me, I would have all diagrams out on the table along with my aftermarket harness, solder and heatshrink all connections from outside the vehicle. Then tie wrap all loose or lengthy wires.
The rest should be plug and play, unless you have to run a GPS antennae, bluetooth mic, sirius tuner, etc.
Old 01-08-2011, 08:35 PM
Rep:3337
Trying to figure out which guage power/ground wire to run to my amps. Have the JL900/5 and 600/4 and approximate 1200W draw, so I'd be looking at 100A. I figure a 4AWG split to 2x8AWG, fused at 110A, power wire. Would I want to combine the grounds with 8AWG to a 4AWG common ground or ground them seperatly?
Also, does it matter the TYPE of fuse I get, I've seen 3 different types, and while they will all work, is there a better type between them?
Are twisted/shielded RCAs worth it?
  #303
Old 01-08-2011, 08:47 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
I'd run separate grounds. It would make things easier. 8ga would be ok, but those amps will accept a 4ga wire. If you do use 8ga, I would keep it as short as possible. Can't really say which fuse to get, I've used minis, maxis, and bus type, all with good results.
  #304
Old 01-08-2011, 09:36 PM
Trim Level: Custom
Rep:1648
I would run 2 ga split to two 4 ga via fused distro block. 150 amp main fuse, 80 amp on the 900/5, 60 amp on the 600/4.......
  #305
Old 01-08-2011, 09:47 PM
chithead's Avatar
Rep:2078
Listen to him, he's pre-law.
  #306
Old 01-08-2011, 09:53 PM
Trim Level: Custom
Rep:1648
It was an online degree.....
  #307
Old 01-08-2011, 10:09 PM
chithead's Avatar
Rep:2078
Nice... that works too.
  #308
Old 01-08-2011, 11:07 PM
Rep:3337
so you'd fuse the main line off the battery AND the two lines to the amps?
  #309
Old 01-08-2011, 11:15 PM
Trim Level: Custom
Rep:1648
Yes....That is correct sir
  #310
Old 01-14-2011, 10:49 AM
boozcruz's Avatar
boozcruz boozcruz is offline
Vehicle: 2011 Ram 1500 Crew Cab
Trim Level: Bighorn
Color: Cherry Red
boozcruz is on a distinguished road
I have the RES stock radio and stock speakers. I know i can replace the speakers, no issue. What i am wondering is if i can add a OEM (kicker) amp to increase the wattage? I had a 2009 challenger stock mygig and i could not install an amp. Can i add an amp to my current RES radio in my new ram 1500?
Closed Thread
