Closed Thread
Old 01-20-2011, 04:30 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Interesting... that might influence my recommendation then.
Old 01-20-2011, 04:34 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
It would be cool if you had some recommendations!
  #323
Old 01-20-2011, 05:41 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Originally Posted by Ryank View Post
Each, the 10w1 v2's i just posted can handle 300rms each, so 600rms for both.
If you run 300 watts RMS you will be reaching its thermal limits, I and JL don't recommend doing that. 200 is better...
http://mobile.jlaudio.com/products_s...p?series_id=15
  #324
Old 01-20-2011, 05:51 PM
Ryank's Avatar
Rep:199
Oh ok thanks.
  #325
Old 01-20-2011, 07:45 PM
BigHorn2010 BigHorn2010 is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Trim Level: SLT Big Horn
BigHorn2010 is on a distinguished road
A couple Questions for the audio gurus here. I've purchased everything for my upgrade to my 2010 ram crew cab (stock 6 speaker non alpine).
I didn't have a ton of cash to spend so I ended up with:
pioneer avh-3200bt
Scosche adapter
Axess metra steering wheel control adapter
Two sets of Polk 6x9's db691
Polk 3.5" for the dash
A sound ordnance 100x4 rms amp (to power the 4 6x9's)
Back up camera
My questions are (I'm new to Dodge) if I want the head unit to power the dash speakers do I need to do anything other than disconnect the factory wiring to the four door speakers because I will be running new speaker wire directly to the amp? And also for the backup camera do I have to tap into separate wires for the reverse signal and parking brake or with the can/bus will everything be taken care of with the wiring harness adapter?
Thanks in advance for any help!
  #326
Old 01-20-2011, 07:54 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
I am getting ready to buy a double-din dvd/nav unit to replace the stock cd player in my truck and would like to do it myself. I am going to order a new bezel that is a factory bezel for the nav system that came as an option. My question is will a aftermarket unit fit this bezel or will there be a gap around it still ? Also can I buy a wire harness to hook up between the new unit and the trucks harness or will I have to splice the wires ? Any input would be Greatly Appreciated, Thttp://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=310289689575&ssPageNam e=STRK:MEWAX:IThanks.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
  #327
Old 01-20-2011, 10:43 PM
shoefstall shoefstall is offline
Vehicle: 2010 dodge ram
shoefstall is on a distinguished road
i just got 2 jl w7 13 in subs put in the guy only put a 600 watt amp on them i also have pioneer 4200 pushing on them do i need to put more power to them?
  #328
Old 01-21-2011, 08:32 AM
chithead's Avatar
Rep:2078
pioneer avh-3200bt
Scosche adapter
Back up camera
I believe you'll still have to tap a few wires for the backup camera. Other than that, all will be good.
  #329
Old 01-21-2011, 08:33 AM
chithead's Avatar
Rep:2078
There will be a gap, you'll still need an adapter kit to make it fit flush. And yes, a wiring adapter is available to make it plug and play with the factory harness.
  #330
chithead's Avatar
Rep:2078
Yes. You do. Anyone that just bought two JL W7 13in subs would know this. I'd like to see pictures please.
Closed Thread
