Closed Thread
Old 01-28-2011, 09:48 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Time to upgrade!!!
Old 01-28-2011, 11:46 AM
BAmes79 BAmes79 is offline
Vehicle: 2002 Dodge Ram 1500 SLT
BAmes79 is on a distinguished road
Originally Posted by chithead View Post
Time to upgrade!!!
Dang So from what I've described you guys are pretty sure it's the head unit? I did hook up my extra pair or MTX 6x9s and it was the same result...
  #373
Old 01-28-2011, 11:52 AM
MADDOG MADDOG is offline
Rep:22
Yup, I'm afraid so. Your head unit is powering your speakers and it seems that it isn't putting out enough power anymore.
Your MTX speakers will want around 40 to 45 watts RMS. They probably max at 80 watts. I'd get an amp to go with a new head unit.
  #374
Old 01-28-2011, 03:56 PM
Well, a new head unit it'll be, I think I'll go the amp route too. Now I'll have to search this 38 page archive to find the best way to go on all that, but thats not a bad thing! Thanks so much for all your help guys!
  #375
Old 01-28-2011, 07:47 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Vehicle: 2008 Dodge Ram
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
So I've been looking around for a new head unit and think I've found one but I have a few questions. The unit says it works with Clarion Navigation so does this meen I have to buy something else to use the navigation ? Also, would I be able to hook up 4 other monitors to it fairly easily ? And can you play a DVD and still listen to music ? I would like to do the install myself and already purchased a factory nav bezel and a install kit that comes with a shroud, wire harness, and antenna adapter. One more question: How do you hook up the factory Sirius radio to this unit, does it just run through the regular antenna wire ? Any advise is greatly appreciated, Thanks.http://cgi.ebay.com/Clarion-VX401-6-...item2c5a5d9579
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
  #376
Old 01-28-2011, 09:13 PM
Irish Irish is offline
Vehicle: 2003 Dodge ram
Irish is on a distinguished road
I have an 03 dodge ram i just installed a new headunit and apparently in doing so after a couple days working i took it out to plug in an ipod , Then the power shut off, i tested all the fuses in the engine bay. and a few of them on the harness where getting power too but not all now my stereo wont turn on and my alarm and auxilarry power wont work like my cabin lights wont turn n when i open my door but they will after i start my truck any idea whats happening?
  #377
Old 01-29-2011, 04:07 PM
plumcrazy68 plumcrazy68 is offline
Vehicle: 2010 dodge ram
Trim Level: sport
Color: inferno red
plumcrazy68 is on a distinguished road
is the box sealed or ported? which is your sub made for? What is the insde cu. in., there is a lot more you need to know before you buy subs and throw them in a box. how much and how hard of bass do you want?
  #378
Old 01-30-2011, 09:41 PM
loudrango's Avatar
loudrango loudrango is offline
Vehicle: 97 Ram,96 Ram,98 rango,01 rang
Trim Level: ram slt -rango r/t
Rep:64
loudrango will become famous soon enough
you should be able to run 4 more monitors off of it if you get a video signal splitter.i had to use one in one of my durangos.as far as the factory sirius,you'd probably need some sort of interface that matches up to your factory sirius to the new clarion.
2005 IASCA Stock 3 World Champion
2004 IASCA World Finals 4th place
  #379
Old 01-31-2011, 01:53 AM
Default Rookie, trying to keep it simple...
I posted a question a couple days ago and you guys helped a lot, so I'm back, thank you by the way. I had the bad factory head unit in my '02 that was powering my rear speakers just fine but when I faded to the front the speakers sounded really muffled. I got a new pioneer head unit, antenna adaptor, wiring harness adapter, a 200W 2 channel amp (I know not the best choice for now but the budget was limited so I borrowed this for now), a pair of MTX 6x9's, and can use either the factory rear speakers or I have a pair of pioneer 6 1/2's I can put back there.
My question is can I connect my 4 speakers to my 2 channel amp and still get fade front and back? If so, what's the recommended way?
If not, can I run my front speakers through my amp (just wiring them like normal) and my rear speakers through the new head unit by simply connecting the wires from the new harness adapter to the harness in my stereo? (this is what I would like to do for simplicity sake)
Or, what's the easiest way to get them all working and sounding good? That's all I'm really going for here. Thanks again!
Or, what is the easiest
Last edited by BAmes79; 01-31-2011 at 02:17 AM. Reason: To make my question more clear.
  #380
Old 02-02-2011, 02:31 AM
Kearns16's Avatar
Kearns16 Kearns16 is offline
Vehicle: 2010 Dodge Ram Sport
Color: Deepwater blue
Rep:25
Kearns16 is on a distinguished road
Hey guys i have a 2010 ram qc.. And was thinking about getting an aftermarket touch screen radio... If so do i need to buy an adapter to keep my steering controls to stay working.. And ne sugestions on what would b a good one to buy?!
Closed Thread
