Have Audio Questions? We've Got Answers! - Page 4 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Closed Thread
Old 09-13-2010, 09:47 AM
boostaddicted05 boostaddicted05 is offline
Vehicle: 2004 Dodge Ram 2500 4x4
Color: Blue
Rep:17
boostaddicted05 is on a distinguished road
Originally Posted by dodgeman70592 View Post
Is there a blue wire not being used on the Scoche harness you have?
Yes. I believe so. Whats the problems with the infinity system.
Old 09-13-2010, 09:57 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
From what I have read (never attemted this either, so take it for what it's worth)
I read that you can connect the remaining blue wire from the Scoche harness to the remote turn on wire from the aftermarket harness, and it SHOULD work. While I don't recommend this route, it may be an option.
As for the issues with the Infinity system......
First, they use some of the cheapest drivers imaginable coupled with a second rate at best amplifier and then separate frequencies between speakers that make no sense. Instead of sending full range signal each speaker, and using inductors or inline crossovers, they sent bandpassed signals from the amp, that makes it all but irrelevant to change your speakers. I am sure you will read about lots of folks complaining that after they changed the Infinity speakers to something else aftermarket, they are not pleased with the output.......well, this is why.
If it were me, I would completely bypass it all together and install my own drivers and amplifiers, but thats me....
  #33
Old 09-13-2010, 09:59 AM
Trim Level: Custom
Rep:1648
Originally Posted by LoveMyHemi View Post
I just finished adding a few things to the outside of my truck and now I'm looking at improving my audio setup. I have the infinity sound system which I like, but I'm looking for more bass. Are you able to get a good amount of bass even with the small air space under the seats?
Thanks,
David
Yes, you can get a decent amount of space using the underseat area. You will have to add an aftermarket amplifier to the system to power the sub(s), for the Infinity amp doesnt have the power available
  #34
Old 09-13-2010, 11:14 AM
LoveMyHemi LoveMyHemi is offline
LoveMyHemi is on a distinguished road
Thanks Jared, Is there a box that you recommend? Or will any cheapo wood box work fine?
  #35
Old 09-13-2010, 11:31 AM
Trim Level: Custom
Rep:1648
I am not a big fan of the cheapo's for the lack of airspace, but, if you are using a sub or subs that dont require much, you should be fine..
  #36
Old 09-13-2010, 01:51 PM
Color: Blue
Rep:17
Thanks dodgeman for the help and understanding. What size amp would you recomend( output) and ive done some audio but im not sure what the drivers are. Thanks again.
  #37
Old 09-13-2010, 01:55 PM
I hate doing things the cheap way. If you're going to do it, do it right.... What box would you recommend?
  #38
Old 09-13-2010, 02:15 PM
Trim Level: Custom
Rep:1648
Hmmm, well, from what I have experimented with, 200-300 Watts RMS for 1-10" or 12", and 400-600 for 2 subs. Just make sure you are looking at true RMS power and not the "marketing scheme" peak power. One easy way to tell is by the size of the onboard fuses if they have them. Figure 100 true watts per 10 amps, so if it has 2-30amp fuses, you should be good for 600 watts.
http://www.foxacoustics.com/SearchResults.asp?Cat=23
http://caraudiofactory.com/-c-22_28....64e843487d17dc
Be sure to check mounting depth and air space requirements on your sub(s) to ensure proper ventilation and mounting.
  #39
Old 09-17-2010, 10:13 PM
lbheyman's Avatar
lbheyman lbheyman is offline
Vehicle: 2009 Dodge Ram
lbheyman is on a distinguished road
I am installing an Alpine deck and amps in my truck. What harnesses do I need? How do I bypass the factory amp?
  #40
Old 09-17-2010, 10:23 PM
Trim Level: Custom
Rep:1648
I am guessing you have the stock Alpine system?
Closed Thread
