Closed Thread
Old 03-01-2011, 10:23 AM
I push the skinny pedal
Rep:3277
The parking brake grommet would be my recommendation as well. I use it for most wires running out of the cab (lots of 'additional' lighting)
Kurtis
Old 03-02-2011, 05:04 PM
Shakn440 Shakn440 is offline
Vehicle: 2010 Ram 3500
Rep:12
Shakn440 is on a distinguished road
Default 2010 Ram 3500 Audio questions
I have a few questions and thanks in advance for any input.
I have in my 2010 the RER Media Center with the Nav. Any feedback on the new Media Centers in the 2011? The reason I ask is a friend, just picked up a 2011 Laramie with the Media Center and Nav, there is a feature that I would really like. It alerts of an incoming text and you can reply to the text as well through the system hands free. The issue is that the majority of my communication is now texting...less and less phone calls, so this feature would be really nice.
So a few questions, any chance there will be a firmware update to the current 2010 Media Center that would allow this?
If not will the new 2011 Media Centre plug and Play to the 2010 truck?
  #453
Old 03-02-2011, 05:15 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I have not heard of any firmware update for the RER that would allow that. I have an RER in my SRT8 Chally.
As for swapping units, I honestly see no reason why you cant, they all operate on the same bus speed in the 4th gens. Would your friend let you swap units with him to find out?
  #454
Old 03-02-2011, 07:11 PM
Rep:12
good point....swap it out and keep on driving LOL...get it back to ya in a week or so.
I know there is updates in technology but I hate when they come out with something you really could use a few months after you buy.
  #455
Old 03-02-2011, 08:07 PM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Hey got a question, where's the best place to put an amp in a 2001 dodge ram, and where's a good place to run the RCA and remote wire, because I know you shouldn't run it with the power wire, so could I run it up he middle of he truck, or what???
Thanks
Ryank
  #456
Old 03-03-2011, 08:07 AM
Trim Level: Custom
Rep:1648
Thanks
Ryank
Easiest place for you would be under one of the seats. As long as RCA's are ran on the opposite side of the truck as the power wire you are fine.
  #457
Old 03-03-2011, 07:14 PM
Ryank's Avatar
Rep:199
Thanks! so if i where to put the amp under the drivers seat, the power would be easy because thats the side of the truck the battery is on, but where would i ground it? and how would i get the RCA's and remote wire under the carpet to the to the other side?
  #458
Old 03-03-2011, 07:32 PM
sk8noregon's Avatar
sk8noregon sk8noregon is offline
Rep:637
sk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to allsk8noregon is a name known to all
Question: I really want to upgrade the stock head unit in my 08 Ram. It is a single CD Player with Factory Sirius. I want to get a Double-Din unit with DVD/Nav and Sirius Ready with Dual-Zone so I can run the headrest monitors off of the head unit. I have found several units but most of them aren't Sirius Ready. Would I be better off going with the OEM Nav unit that was an option in 08 ? And does it play DVD ? And could I run my headrest monitors off of it ? I am also unclear as to what else I would need if I went this route. Would I need other stuff to use the DVD and Nav, or is that all built-in ? I already have a factory Nav bezel and a install kit with wire harness, antenna, and plastic surround piece. Any input would be great, Thanks.
"Rocky and Bullwinkle"
Join the "Mineral Gray Metallic Ramz Group" here !
  #459
Old 03-04-2011, 08:17 AM
Trim Level: Custom
Rep:1648
What I recommend is find a good spot on the floor of the truck, buff off the paint of that area with a dremel, drill a hole and install a ground lug like this....
As for how to run to the other side of the truck.....Easy, take the seats and door sill panels out to be able to pull back carpet to gain access to the entire floor. You can then loom or techflex your wires and run them where they need to go, and properly secure them.
Well being you have the Nav bezel, harness, double din kit, and antenna adapter, the rest is easy.
There are quite aa few decks that have what you are looking for, just depends on your budget.
  #460
Old 03-05-2011, 05:23 PM
DeputyNelson's Avatar
DeputyNelson DeputyNelson is offline
Vehicle: 1998 Dodge Ram 1500
Color: Red aka AWESOME!
Rep:86
DeputyNelson will become famous soon enough
What's the din size of the radio for a 98 Ram? I'm starting to look at options for cd decks and was wondering what my options are. Thanks!
"Blessed are the peacemakers, for they shall be called the children of God" Matthew 5:9
Closed Thread
