Closed Thread
Old 03-28-2011, 10:26 PM
MADDOG MADDOG is offline
Rep:22
Good choice, Dillon! Can't help ya with your question but I am sure our audio experts can.
Old 03-29-2011, 09:18 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Okay so I am ready for some BASS!!!
I have a 10" JL w7 and I just bought a JL 500/1 amp(still waiting for it to come in though)
So my question for y'all is should I build a ported box or a sealed box? Thanks guys.
PORTED. End of discussion. Unless you need box size and tuning frequency.
  #493
Old 03-30-2011, 06:31 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Thanks Daniel. I'm hoping I will have time sunday to go buy some MDF and get to work!!
Dillon-aka, The Little Kid
  #494
Old 03-30-2011, 08:54 PM
zmurphy's Avatar
zmurphy zmurphy is offline
Vehicle: 2003 Ram SLT CC
Trim Level: SLT 4wd CC
zmurphy is on a distinguished road
Hey guys after doing a ton of searches i still need some advice on installing my amps in my 2003 Quad Ram. I am installing 1 Alpine mrp-f250 and 1 Alpine mrp-350. I plan on running a 4 ga power cable from the battery to a fused distribution block under the front seats.
First question, where is the best place to come through the firewall?
Second question, i have install a few car audio systems before (in my Jeeps and Nissan trucks) but nothing as nice as a Ram. I want to make it look like a professional install. So my question is, whats the best way to mount my amps? straight to the floorboards, use self tapping sheet metal screws, pre-drill the mounting holes and use regular sheet metal screws.......? I know it kina of a silly question, i just want it to look good.
Thanks!
  #495
Old 03-31-2011, 04:59 PM
Rep:22
Thanks!
One of the larger sealed openings is just above and a little bit to the left of the steering column. Take a look at your firewall. There's another one on the opposite side but is hidden behind heater and HVAC boxes and hardware. A lot harder to get to.
My amps are mounted to the floor with self tapping screws. No problems encountered.
  #496
Old 03-31-2011, 09:54 PM
chithead's Avatar
Rep:2078
Best place to pass through is the clutch master cylinder block off plate right next to the brake booster. It is plastic, has two bolts holding it on from the inside.
I agree with Michael, sheet metal screws are fine. Just make sure you don't puncture anything important on the other side (wires, brake line, fuel line, etc...).
  #497
Old 03-31-2011, 09:59 PM
Rep:22
That is ^^^^ the one I was referring to. I've got two holes in mine...front aux light wiring and audio wiring.
I was looking at the service manual and while it's not listed there appears to be one down near the lower portion of the firewall right where the vertical face ends. This must allow for gaining access the the lower area and running thing along the inside base of the floor over to the sills.
As Daniel says, check underneath your truck to make sure your install screws won't poke a hole where you don't want one. And you don't need really long screws.
  #498
Old 04-01-2011, 10:24 AM
zmurphy's Avatar
thanks alot guys! as they say a picture says a 1000 words! i'll be out of town working for the next week but when i get back i'll ge started on my install and maybe even post some pics.
any recommendations on where to buy my power, rca's and fuse holder from?
thanks again guys.
  #499
Old 04-04-2011, 01:47 AM
husky1213 husky1213 is offline
Vehicle: 2005 Dodge Ram 1500 Quad Cab
husky1213 is on a distinguished road
Default Putting in a sound system and needed a little advice
I'm looking to throw a system in my truck and had a few questions...
Which one of these enclosures would you suggest: http://caraudiofactory.com/-c-22_28_...64e843487d17dc
Does anyone have the under the seat type? Does it distort the sound? Would a single on both sides, pointing at each other be bad?
Second: I have the 2005 Dodge Ram 1500 Quad Cab and was wondering what type of amp I should get. I plan on replacing the speakers since they are about to go already and didn't know if I should get 2 amps or 1 since I'll be powering 4 speakers and one (possibly 2 subs). Also I'm going to get a head unit but I'm guessing I would just run that off the battery.
I'm really new to the car audio and figured I bought the truck with the motto "Go big or go home" so why not the sound system too.
  #500
Old 04-04-2011, 04:11 PM
Rep:22
thanks again guys.
I got all my wiring kits and rcas, etc...from onlinecarstereo.com and couldn't be happier with the products and customer service.
Closed Thread
