Closed Thread
Old 04-11-2011, 10:40 AM
kmdracer's Avatar
kmdracer kmdracer is offline
Vehicle: 03 Ram QC , 08 CSRT4
Rep:43
kmdracer is on a distinguished road
Anyone else think I got a bad unit? I just purchased a Kenwood KDC-BT848U and installed it in my 03 Ram (along with the MTX TA3404 amp) I'm only running some Polk 6.5 comps in the front and Polk coax 6.5 in the rear at the moment. When I wired up the amp, I ran a pre-amp cable to the H/U for a future sub amp.
The problem I am having is that I can't get any music to play from the CD, aux OR usb. ONLY through the tuner. I've just downloaded the real manual for the H/U (it only came with a quick start guide) am I am looking online for anyone else with the same problems.
EDIT: Disregard the above. I figured it out (with Kenwood's surprisingly fast Tech Support) Some how I had the amp remote switched by the head unit's power ant. wire (blue) instead of the Amp switch (blue/white).
All is well now. hahahah
Last edited by kmdracer; 04-11-2011 at 01:16 PM. Reason: Found the problem. Duh! lol
Old 04-11-2011, 05:24 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Okay, well it turns out I got scammed buying my amp, paypal got us our money back though. So I got to thinking and I don't want a JL 500/1 amp. I think I want something around 750watt RMS at 3ohms. I'm trying to stay under $300 and I don't know what to buy. Any of you audio gurus have any suggestions?
I would still get a 500/1, you wont be sorry...
Originally Posted by boswell171 View Post
Have a '11 Laramie with the upgraded audio system. I am not overly impressed with the sound output...have it set for mainly fade to the rear with emphasis on the bass and turned down the trebble. I would like to replace the factory amp with something more powerful. What would you reccomend?
The 4th gens all have amps, whether Alpine or not, but replacing them isn't that easy. The head units send a 6 wire bus signal to the amp, therefore the headunits are deadheads so to speak (meaning they cannot play on their own without a bus style amp) So, assuming you want more bass, the easiest thing to do is get an LOC, aftermarket amp, and new sub(s), and basically piggyback the factory amp.
Originally Posted by comerjoshua View Post
I got my truck about a year ago and only one speaker worked so first thing I tried is replacing the head unit that didn't fix the problem so a week ago I bought new speakers and this did not fix the problem either any ideas. Do i have to replace the wiring.
Probably means nothing but the speaker that works is the passenger door.
Did your truck have the infinity system?
Originally Posted by 08blackbighorn View Post
OK so I surfed through 24 pages before I decided to join and ask lol....
I'm no stranger to car audio myself, having worked in the field, held competitions, and competed myself. I finally decided to start my audio project in my 2008 Ram Hemi Big Horn, and have run into a bit of a problem. I am installing a Kenwood KDC-X889 head unit, Alpine Type X pro speakers, Image Dynamics IDMax 10", Butler Audio TDB 275, and an Alpine PDX 1.1000. I installed the head unit using the "basic" wiring kit, grabbing the trigger from a 12v source. The h/u turns on and works great with key on, so I went for a drive and the door locks and interior light were cycling on their own. I can't find any reference to the second 3 wire harness that was plugged into my factory radio, I'm assuming can bus, but even Mitchell doesn't show this 3 wire (all green with tracers) harness. Any clues??
Thanks!
The second three wire harness goes to the factory sirius box. As for your issue, what 12v source did you use?
  #513
Old 04-13-2011, 01:49 AM
deathdealer21 deathdealer21 is offline
deathdealer21 is on a distinguished road
so on a 4 channel do you tie your dash to the front door speakers?
  #514
Old 04-13-2011, 09:03 AM
Trim Level: Custom
Rep:1648
My advice is to use an LOC tied into the front factory channels to get your incoming signal. Then run new speaker wires to front door and dash from 4 channel amp.
  #515
Old 04-13-2011, 08:43 PM
HemiSooner's Avatar
HemiSooner HemiSooner is offline
Vehicle: 2008 Dodge Ram 1500 Big Horn
Color: Silver Metallic
HemiSooner is on a distinguished road
just put the same system i had in my old car in my truck, Alpine H/U , Fosgate Amp, and 2 10" Sony Explodes..... i have had the same system in 2 other cars..... the only thing new is the amp kit (8gauge) and sub box..... i hooked everything up, H/U works great, amp comes on subs dont hit like they did before, i have never never touch any setting on the amp and those subs use to hit pretty hard, so i start to mess with the GAIN on the amp a bit, i noticed that when i turn the GAIN down on one sub the other hits hard and vice versa..... i have no clue whats up.
  #516
Old 04-13-2011, 08:47 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Ummm... did you have them in ported enclosures before? Or always sealed?
  #517
Old 04-13-2011, 08:52 PM
HemiSooner's Avatar
always sealed, before it was 2 separate boxes and now 1 under the bench box. and when i lower the GAIN on one the other works really good (that goes for both)
  #518
Old 04-15-2011, 01:29 AM
loc? what is that
  #519
Old 04-15-2011, 09:01 AM
chithead's Avatar
Rep:2078
loc? what is that
It's abbreviation for line out converter
  #520
Old 04-16-2011, 02:20 PM
BULL1TT BULL1TT is offline
Vehicle: 2007 Dodge Ram Laramie Hemi
Color: BLACK
BULL1TT is on a distinguished road
Send a message via MSN to BULL1TT
Default Adding two 10" subs in my 07 quad cab.........
I have tried to look in this thread but soooooooo many pages. This is for my 2007 quad cab 4x4, Here are my questions.
I want to put an underseat sub box for 2 10" subs. I have found this box.
http://www.technooutlet.com/peatra20210cp.html
What is the max depth (Sub Depth) I can use. I see numbers like 169.2 mm deep for Pioneer subs I found.
Is there a certain depth that I should stay under? I was hoping that someone may have bought a similar box and have found this out.
Also, regarding powering the subs I found these pioneer subs.
http://www.millionbuy.com/view_produ...SUBWOOFER.html
Power handling is 3000 watts Peak and 800 watts RMS. I Know that underpowering a sub is bad vs overpowering and turning the gain down. With that train of thought, should I use an amp that is 2 channel that will put 1000 watts to each sub and keep the gain at about 40% power?
Thank you for the advice in advance, I have never really done my own install before and would like to be a bit more knowledged before I start buying this stuff.
Closed Thread
