Closed Thread
Old 04-16-2011, 08:13 PM
Anthrax96 Anthrax96 is offline
Vehicle: 2008 Dodge Ram 1500
Anthrax96 is on a distinguished road
Default Inifnity sound help!
I have a 2008 Dodge ram 1500 5.7L hemi laramie with the infinity sound system. I am trying to wire subs and an amp in it but i am getting music through the subs more than i am bass. I am using an rf modulator because i want to keep the stock radio due to steerling wheel mounted controls. I have the system wired through the back Right and Left door speakers. everything is wired properly and i am getting power to the amp and to the subs. What could the problem be!?
Old 04-17-2011, 05:25 PM
New2Ram's Avatar
New2Ram New2Ram is offline
Vehicle: 2007 Dodge Charger R/T
Trim Level: R/T
Color: marine blue
Rep:22
New2Ram is on a distinguished road
Hey guys...I have a simple question that I'm sure that someone else has asked, but there are so many posts on this thread...
I have a 2011 cc sport with the rhb radio and I am adding an amp and single rockford fosgate 10" sub. I have a line out converter and plan on splicing into the rear door speakers for my signal to amp. Does this sound ok? Some one told me that I need to get a JL clean sweep, but will the l.o.c. work? I have installed this same set-up in my chevy that i just traded for this dodge, but never in something this new, just don't want to screw something up on this expensive truck. Thanks
---edit---Ok, I just got done reading ALL 53 pages of this thread and now realize that i guess that i need to splice into the front speakers and not the rear. I am not going for spl, just a little low end, so the loc will work? I really don't want to spend 100's of $ on a clean sweep. I still would like someone just to tell me I am going about this the right way...I don't want to mess anything up. Thanks
Mopar Nerf Bars, 3.55 gears, 20% tint, 18" Magnaflow muffler, shorty antenna, 10" Memphis sub, Sound stream amp, AFE stage 2 cold air intake, tri-fold soft tonneau cover, smoke head light and tail light covers, blue l.e.d. brow lights, Built 12-6-10 @ noon
  #523
Old 04-18-2011, 01:50 PM
restes restes is offline
Trim Level: Crew Cab
Rep:30
restes is on a distinguished road
I'm about to replace the RER no nav unit in a 2010 dodge ram with a Pioneer AVH-P3300BT, amp, new speakers and a 10" sub.
Do I need the PAC C2R-CHY4 since i will not be using the factory amp?
Or do i just use a standard harness and steal power from the cig lighter?
How do i power the rear door speakers without running wires all the way back?
  #524
Old 04-18-2011, 10:06 PM
boost4fun boost4fun is offline
Vehicle: 2006 Ram
boost4fun is on a distinguished road
Im sure this has been asked and answered a hundred times but I can't find a answer anywhere. Every place i've checked is giving me different answers. I have a 2006 2500, with the basic radio. I want to replace my speakers in the front and rear. What size replacements do I need to get.
  #525
Old 04-19-2011, 08:12 AM
dodgeman70592's Avatar
Trim Level: Custom
Rep:1648
Why an RF modulator? You could easily just use a line out converter tapped off of the front factory wires.
Yes, tap into the front wires with an LOC and you will be fine, done it plenty of times.
A standard harness, tapping into a switched 12v, run RCA's to new amp(s), run new wires to each door, your done. If you wanted to use the factory wires going into the door, you can tap into them via the front side of the factory amp.
Factory, you have 6" x 9" up front and 5-1/4" in the rear.
  #526
Old 04-19-2011, 05:49 PM
collegekid collegekid is offline
Trim Level: ???
collegekid is on a distinguished road
I got a ProBox that has two 12s in it. It is the under the seat box for my 2008 dodge ram 1500 quad cab. What else do I need? I know I need an amp, what are some good amps to consider? What do subwoofers do? Should I get some? Also does the Pioneer AVH-P4300DVD fit the dodge ram?
p.s. I know nothing about audio in vehicles, subs, amps, etc.
  #527
Old 04-19-2011, 09:37 PM
Rep:30
Thanks for the help
  #528
Old 04-20-2011, 01:58 AM
Trim Level: ???
Thanks for the help
Is this the answer to my question?
And if so, what is a good head unit for the 2008 dodge ram? I was looking at the pioneer AVH-P4300DVD but I don't think it fits my truck.
  #529
Old 04-20-2011, 09:30 AM
Trim Level: Custom
Rep:1648
Did your truck come factory with the Infinity sound system, or is it the basic 4 speaker setup?
That headunit will work, but you will need a couple of things (assuming you dont have a factory double din)
Dash kit - http://www.metraonline.com/part/99-6510
Wiring harness adapter - http://www.scosche.com/car-audio/product/510
Antenna Adapter - http://www.metraonline.com/part/40-CR10
Nav Bezel (accoding to your stock interior color) - http://shop.ebay.com/?_from=R40&_trk...All-Categories
As far as amps, subs, etc are concerned, it's very subjective. I would suggest heading down to your local audio shop and have a listen to see what you like.
  #530
Old 04-20-2011, 10:27 PM
New2Ram's Avatar
Trim Level: R/T
Color: marine blue
Rep:22
Thanks for your answer on the loc and wiring locations. But...I have another question now. I have a rockford 10" he2 dvc 4 ohm wired parallel for 2 ohm. My amplifier is a soundstream angina rubicon. The manual I found online says that it is 100w rms @ 4ohm and 200w rms @2 ohm. I have everything wired correctly with no shorts, but the 15amp fuse that is mounted on the amp blows when played at high volumes. Gain is set at 2/3, and only blows when pushed decent. The amp gets hot now, the last sub I had it wired to was a 4ohm and I never had any problems.Low volumes it is fine. My main fuse on the 4ga power wire is fine. Any ideas?--thanks, Joe
Closed Thread
