tonneaucovered.com
Closed Thread
Old 05-06-2011, 11:12 PM
ramz11's Avatar
ramz11 ramz11 is offline
Vehicle: 2009 dodge ram
Trim Level: sport
Color: mineral gray
ramz11 is on a distinguished road
Hi i am losing my mind on my nav radio install on my 09 sport crew with the alpine system.i have a kenwood dnx6160,metra axxess harness and aswc steering wheel control box.made the mods to inner dash and hooked everything up.worked awesome just sounds horrible was fading front to back on its own.the sound was distorted and the volume has to be up pretty much all the way to here it.i was reading the axxess stuff maybe is not that great and i should have gotten the pac harness instead.all i want is for it to sound a little better or exactly like stock.anybody ever run into this.any answers would help my headache.thanks
Old 05-06-2011, 11:14 PM
MADDOG MADDOG is offline
Rep:22
All I can say is that I've only used PacAudio harnesses and never had a problem. It could be the Metra but I don't know enough about how you wired things up to definitely call it the root cause.
  #553
Old 05-06-2011, 11:25 PM
ramz11's Avatar
Trim Level: sport
Color: mineral gray
It seems to me the metra kit is no good.how did the pac harness sound after u wired it.like stock or better.does not make sense that the stock radio sounds way better,just hooked up the speakers to the rca wires provided with the metra kit.
  #554
Old 05-07-2011, 12:07 AM
Rep:22
The PacAudio harness just passes signals through. So sound quality is dependent on your components, not that harness.
So, since I have a nice JL 4 ch amp and some Hertz HSK 165.2 2-way component speakers, mine sounds just fine.
  #555
Old 05-09-2011, 01:27 AM
Mikel Mikel is offline
Vehicle: 2006 Dodge Ram Quad Cab
Trim Level: SLT Lone Star
Mikel is on a distinguished road
Me too
+1
[IMG]http://mikel.com/images/Image2.jpg[/IMG]
  #556
Old 05-10-2011, 12:18 PM
Folden's Avatar
Folden Folden is offline
Vehicle: 2000 Dodge Ram
Rep:20
Folden is on a distinguished road
Default Bed Box???
2000 Dodge Ram Quad Cab. I need some information on upgrading to a Bed Box! I have 2 12" Memphis 3 Subs and there is no way they would fit in an under seat box. I have the 1100 Watt memphis D Class Amp. I basically need info on getting the rubber boot and other information you may find necessary. I don't want to use the cabin because I now have a newborn and a 6 year old child and need the seat space.
  #557
Old 05-10-2011, 03:25 PM
Grundy Grundy is offline
Vehicle: 2009 Dodge Ram 1500
Color: Sunburst Orange
Grundy is on a distinguished road
Default Touchscreen radio question
I have a 2009 ram with the REN radio (no GPS). When I'm using the HDD, turn the truck off, come back the next day, it does not pick up right where I was. If I'm using the cd player, the next time I get in and turn it on, it starts at the beginning of the cd instead of where I left off. I have the RES (with GPS) in my jeep and it does these things. Is this supposed to happen? It doesn't make sense that it would start at the beginning of the cd or not pick up where I left off on the HDD. Anyone else having this issue? Is there a fix? Thanks.
  #558
Old 05-10-2011, 03:44 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
are the factory speakers in the crewcabs rear headliner, the same size as the ones in the dash, 3 1/2" ????? I want to upgrade all my speakers, and even Crutchfields does not offer any info on these 2 in the headliner....Thanks
So it is written ! So it shall be done!
  #559
Old 05-12-2011, 02:57 AM
collegekid collegekid is offline
Vehicle: 2008 Dodge Ram
Trim Level: ???
collegekid is on a distinguished road
K I just bought a ProBox with two ProBox 12s subs in it. Now all I need is an amp right?? What kind of amp should I get and what WATT?? IDK anything about this stuff. What amp would go good with that ProBox??
  #560
Old 05-16-2011, 02:00 PM
Cubanu Cubanu is offline
Vehicle: 2003 Ram 1500
Trim Level: Quad sport slt
Color: Dark Gray
Cubanu is on a distinguished road
Hey guys! So here's my situation I have a 10w6v2 in a JL sealed enclosure. JL says the box is .625 cb, th under seat enclosure for the quad cab says it's .5 cb. My question is will it still hit hard? Also I was looking into a kicker 10IX500.1 to push would that be a good option? I would be running the JL at 2ohm. Thanks
Closed Thread
