Place your Ad Here!
Closed Thread
Old 06-02-2011, 10:20 PM
MADDOG MADDOG is offline
Rep:22
vtelvr, from what I've read here, upgrading to the next level of MOPAR head units is pretty much a plug and play. Going from the so-called Infinity system to the REC NAV unit in my truck was.
Yes, you can add amps and aftermarket speakers pretty easily. If you put in a new amp, your stock one stays in place and is used to send a digital signal to the new amp. Also, some harness adapters from PacAudio will be needed to preserve steering wheel control operation and to incorporate the amp. If you go to an aftermarket head unit, that will also require an adapter.
You can get a Double DIN bezel (if you don't already have one in your truck) for either upgrade.
I can't recommend a head unit but if you want navigation, look for one with the Garmin NAV interface. It's the best looking, easiest to use NAV I've seen.
Old 06-02-2011, 10:23 PM
Rep:22
Originally Posted by SteelerMegaCab View Post
Hi all. I just joined. First post. Simple question. I think my head unit is a 730N. Are there video outputs on the back to run headrest monitors? Does anyone have a picture of the back of one. Sorry, I didn't do any searching. Thanks!
Welcome to the forum!
Sorry, I don't know if the 730N has rear video outs.
  #583
Old 06-03-2011, 06:44 AM
vtelvr's Avatar
vtelvr vtelvr is offline
Vehicle: 2011 Ram Express
Trim Level: Express 1500
vtelvr is on a distinguished road
Awesome info man! I really like the "stock" clean look of OEM head units. When you start adding all the extra dash pieces to an aftermarket one, it starts to look cheap. Not my taste. I think I have the RES radio. It has satellite radio, and the uconnect buttons, but the uconnect is not operable. I really don't have a preference towards the UC, and if it never worked, I would be broken hearted.
I will look to see if I can snag an OEM nav from someone who has upgraded. I do not have the steering wheel buttons, which doesn't bother me either. Even just a simple head unit and upgrade to some high end door/panel speakers would make me happy. I really don't need the sub in my truck as small as it is. The wife would probably agree to that as well.
  #584
Old 06-03-2011, 01:19 PM
Blue Streak Blue Streak is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Rep:63
Blue Streak will become famous soon enough
I have a 2011 CC with alpine. I'm looking to put comp in front and 6.5 in rear and would like to add a 10" sub. I like the Alpine PDX5 for the amp. What would I need to hook it up using the factory head unit. Also what gauge speaker wire would you recommend for the speakers and subs. I also have the ALLGIG to install.
Thanks in Advance!!
  #585
Old 06-05-2011, 07:57 PM
Boilerup15 Boilerup15 is offline
Vehicle: 2004 Dodge Ram
Rep:25
Boilerup15 is on a distinguished road
I have 2 10" Rockford Fosgate subwoofers, is there a box that these will fit in for under the back seat? Mounting depth is 5.75", cubic volume for a sealed box is .50-.85.
  #586
Old 06-08-2011, 08:49 PM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Hey guys,
Trying to install my two 12" type R's.
I was wondering how to tap into the stock deck to get a set of RCAs out without ordered any fancy connectors.
I do have a RCA converter with a brown, black, grey, and green wire coming out of it.
Just wondering which wires I could tap into???
Ive been doing some research on here and no distinct answer.
People were saying to tap into the Front door speakers???
Thanks
Old 06-09-2011, 05:30 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
Default What all would I need?
I've got a 130 (RES) without the unconnect module. If I were to get my hands on a 730N (RER) what all would I need to make everything work? I've got the antenna for Sat radio, will that work for the nav system?
Thanks
  #588
Old 06-25-2011, 02:15 PM
xbxjunkie's Avatar
xbxjunkie xbxjunkie is offline
Vehicle: 2008 RAM 1500
Trim Level: LARAMIE
Color: SUNBURST ORANGE
xbxjunkie is on a distinguished road
Default Ref upgrade
My 08 Laramie has a REF radio in it SAT and UCONNECT. I would like to upgrade it to the factory NAV unit. Does anyone know if this is a plug and play swap? besides changing the front bezel, what else has to be done.
2008 RAM 1500 * HEMI POWERED * LOOKING FOR MODS *
  #589
Old 06-28-2011, 07:59 PM
NORFLA71's Avatar
NORFLA71 NORFLA71 is offline
Vehicle: 2008 Ram 3500
NORFLA71 is on a distinguished road
Default Guys,
Sorry to ask, as it may have been answered, but 50+ pages is too much to sift through.
I have an 08 QC Laramie and am generally satisfied with the stock system, though not the bass response. I have been looking at custom underseat rear enclosure for a pair of 10's. How can I hook an amp up to the stock head unit?
Stock, for now...
  #590
Old 06-30-2011, 10:30 AM
Bryanp's Avatar
Bryanp Bryanp is offline
Vehicle: 2007 Ram 1500 4x4 Laramie
Color: Inferno Red
Bryanp is on a distinguished road
Originally Posted by chithead View Post
Here's another great help (fast forward to 1:05 if you don't have the center console):
Thank you thank you thank you. I can now stop smashing my forehead on the keyboard while looking for that exact information
2007 RAM 1500 4x4, taken away too soon.
2011 RAM 1500 4x4 Big Horn
Closed Thread
