Closed Thread
Old 09-13-2011, 08:57 PM
jleist jleist is offline
Vehicle: 06 ram 1500
Trim Level: big horn
Color: red
jleist is on a distinguished road
ok cool ill try that! i guess ill just go from under the dash and hook it up to both front! thanks
Old 09-13-2011, 09:06 PM
Color: red
would it make a difference on the kind of line converter i use? i seen some that require power and ground wires! what would u use?
  #663
Old 09-14-2011, 12:40 AM
Color: red
Default where can i find the output wires for the stock amp
looking at the amp mounted behind the glove box wich is the output side the one in the back or the front? im guessing the back because when i spliced in my line and hooked in my line converter my sub bumped and my frount speaker were very low. but i do not see the right color wires that mach what is going into the speakers. so does anyone know where i can find the front speaker wires after the amp so i can hook up my line converter? thanks
  #664
Old 09-14-2011, 03:43 PM
MADDOG MADDOG is offline
Rep:22
I'd try the front lower kick panels right in front of the doors. that's a great place to mount one.
  #665
Old 09-16-2011, 09:45 PM
race06074 race06074 is offline
Vehicle: 2011 Ram R/T
race06074 is on a distinguished road
Default 2011 RAM R/T..Newbie here
Hi all, i just got a 11 ram r/t and today the stereo on full volume was at the level of where i would listen to it normally. played with some buttons on the nav to see if i had hit anything, couldnt make it come back. got home, parked truck, 10 min. later moved truck, stereo was fine. it was mainly the door speakers that seemed real low. any ideas? did i hit something?
  #666
Old 09-17-2011, 01:21 AM
Rep:22
Welcome to the forum! Sounds like one of those weird momentary glitches that no one can diagnose.
But were you messing around under the dash for some reason?
  #667
Old 09-17-2011, 09:43 PM
No sir. Havent touched the truck yet. Has 100 miles on it.
  #668
Old 09-19-2011, 12:11 PM
Twin4573's Avatar
Twin4573 Twin4573 is offline
Vehicle: 2005 Dodge Ram
Twin4573 is on a distinguished road
I have a 2005 Ram 1500 Quad. What 6x9s will fit? I have a aftermarket sony radio with built in amp. I installed Pioneer 6.5 in the rear and plan on adding sub amp and one 12 under seat soon.
  #669
Old 09-20-2011, 09:07 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
As long as you have a mounting depth of 3" or less you will be fine.
  #670
Old 09-20-2011, 09:31 PM
MileHighRango MileHighRango is offline
Vehicle: 2004 Dodge Durango
Trim Level: Limited
MileHighRango is on a distinguished road
Default Help!
i just purchased a radio from a 2010 ram, and a U-connect harness for it. The install vehicle is a 2004 Durango with the infinity system, can someone help hook this up? i am very experienced with electronics and not afraid to cut wires. The connectors don't match as i had hoped so i believe i need to make some modifications. I can get a lot more info if some think they can help!!!
Closed Thread
