tonneaucovered.com
Closed Thread
Old 09-24-2011, 04:18 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
There are no bolts like in the 3rd Gen Rams so it won't be as easy as removing it, drilling it, then bolting it back in.
So are 4th Gen guys just drilling it in place? What's behind there?
2012 R/T 392
Old 09-24-2011, 04:27 PM
MADDOG MADDOG is offline
Rep:22
Don't know what the 4th gen folks are doing but I just drilled through the plug to be able to pass a wire through.
  #683
Old 09-24-2011, 05:20 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Well, here goes nothing! LOL
2012 R/T 392
  #684
Old 09-27-2011, 08:06 AM
Frank Drebin Frank Drebin is offline
Vehicle: 2011 RAM CC SPORT
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:34
Frank Drebin is on a distinguished road
There are bolts from the inside, and the plate can easily be removed.
Three Generation Dodge Ram Owner - 1998, 2003, 2011
  #685
Old 09-30-2011, 07:25 PM
tat2dwiseguy's Avatar
tat2dwiseguy tat2dwiseguy is offline
Vehicle: 2012 RAM 1500 SPORT
Color: Deep Cherry Red Pearl
Rep:64
tat2dwiseguy will become famous soon enough
Ok, Crutchfield couldn't help, and I don't want to sit here all night on a friday and read through 53 pages of posts to see if it's answered, but it's not obvious on the main A/V page.... I need a wiring diagram for the 2009 1500 Crew with the RES head unit so I can do a simple line out converter and sub install. Anyone out there have an accurate schematic for 2009? PS, I don't a factory amp. That seems to be the source of confusion, as everything is either for the 2500 or 1500 with amp.
  #686
Old 09-30-2011, 10:20 PM
voodoochi1d's Avatar
voodoochi1d voodoochi1d is offline
Vehicle: 2009 Dodge ram 1500 slt
Color: silver
voodoochi1d is on a distinguished road
Im not sure if Im right but, I upgraded to a RER and I had a RES unit. Would the schematic/pin out for my 2009 be any different than if my truck had come with a RER unit?
  #687
Old 10-04-2011, 08:45 AM
LCJr's Avatar
LCJr LCJr is offline
Vehicle: 2005 Dodge Ram 1500
Color: Light Almond Pearl Metallic
LCJr is on a distinguished road
Default Request assistance with speaker install and amp question
Hey Guys,
I have a 05 Quad Cab with 5 speakers in the rear doors (passenger side speaker missing). I understand from this forum that 6 or 6 inch speakers will fit. My question is, how do I get the bigger speakers to fit? Im an office guy without a lot of technical skills or time. Is there a how to on this?
Also, when accelerating, the amp(?) behind the glove box under the dash is buzzing like interference perhaps and Im not sure if replacing the missing speaker will fix this or do I need to take my truck to some professionals?
Thanks
2005 Dodge Ram Laramie Quad Cab in Light Almond Metallic.
  #688
Old 10-05-2011, 01:23 PM
MileHighRango MileHighRango is offline
Vehicle: 2004 Dodge Durango
Trim Level: Limited
MileHighRango is on a distinguished road
Originally Posted by dodgeman70592 View Post
I'm pretty sure the bus speed is different between the two, not 100% positive.
This is true.......after a lot of research the Can-Bus speeds are different and there is not yet a harness that allows the new ram's to run a stock system with after market amps so there is not way to make it work...at least without the $400 dash harness, and even then its questionable.
  #689
Old 10-14-2011, 04:25 PM
2500hd's Avatar
2500hd 2500hd is offline
Vehicle: 2010 Ram 2500 HD
Color: Austin Tan
Rep:32
2500hd is on a distinguished road
Call me crazy but my question regards doing the complete opposite of what most are doing on here. I have a 2010 ram 2500. I had the RES radio and I have swapped that out with a RBZ. I am a journeyman tech and parts tech apprentice at dodge so I have access to all the information and part numbers but I am unable to find a wiring harness or such to add a factory subwoofer to my truck. I, unlike most, dont have a problem with the factory system. I am no audio guru so the output of a factory subwoofer is plenty. My question is it possible to add a factory sub to a truck that does not have the harness for it. I would assume I will need the factory amp as well? Basically just want to know if it is possible and what would be involved. I know kicker has there add a sub option that comes with a harness and such but the price is not appealing for me, and reviews say its not much better compared to putting a customer set-up together like most do.
Thanks!
-Amp Research-Fuel Offroad-Nitto-Diablo-Rigid Industries-Craven-CJC Offroad-Carli-BT-
  #690
Old 10-14-2011, 07:25 PM
bbessler199's Avatar
bbessler199 bbessler199 is offline
Vehicle: 2011 Dodge Ram Express
Rep:16
bbessler199 is on a distinguished road
Hi all I recently added some audio upgrades to my 2011 Dodge Ram Express. I installed a JL 500/1 amplifier and two 10inch JL 10" W1s. I made it about two weeks before I decided I had to get some speakers to match the awesome bass.
After talking with the local audio guy I ordered a set of Alpine Type R component speakers and a pioneer double din head unit. I also have another JL 300/4 amp that I am going to use to power the new speakers. For now I will just use the new HU to power the rear speakers.
I really like the look of double din head units but a nav unit really wasnt in my budget so I went with this set-up.
http://www.crutchfield.com/p_130P800...rand%7cPioneer
The main reason why I am posting is I have seen some people say you have to buy a nav bezel to install DD head units but then I have seen others say all you have to do is trim a small piece of the sub dash. I ordered a dash kit just in case but I was really hoping I wouldnt have to order the nav bezel.
Thanks for all the help guys!
Closed Thread
