Closed Thread
Old 12-15-2011, 10:45 PM
MADDOG MADDOG is offline
Rep:22
I have done it before. I had the Infinity system. It worked just fine but the amps (stock infinity & kicker accessory 77KICKAB18) are pretty wimpy.
Check out my Ram Mods thread and scroll through it. You'll see where I replaced the dash speakers (super easy) and the door speakers (pretty easy) but the amp took a bit of time if you want to tackle that too.
The speaker change out is super easy.
Old 12-16-2011, 02:41 PM
bigstumpyd bigstumpyd is offline
Vehicle: 2008 Dodge Ram
Trim Level: Laraime Big Horn QC
Color: Dark Gray
bigstumpyd is on a distinguished road
Ok Great! Thank You. I dont really want to change the amp, just replace the speakers. Im sure it is a definite upgrade over stock. Just looking for some good sound not over the top. How did you think it sounded? here is the ebay link just want to make sure I get the correct parts it had a AB after the part number you gave me. The dealer said it would be a few weeks before they could get it.
Thank You Again! http://www.ebay.com/itm/330635759771...ht_3303wt_1002
item number:330635759771
  #743
Old 12-26-2011, 08:34 PM
Color: Dark Gray
Thank You very much! I installed this weekend and it sounds pretty dang good!
  #744
Old 12-27-2011, 05:03 PM
breedsrt breedsrt is offline
Vehicle: 2006 2500
Trim Level: Slt
Color: Inf red
breedsrt is on a distinguished road
I have an 06 srt10 with the rec navi radio. As you may know the radio has no aux or USB hookup. How can I add them to this radio?
  #745
Old 12-31-2011, 03:09 PM
Brutus's Avatar
Brutus Brutus is offline
Vehicle: 2006 Dodge Ram
Trim Level: 4x4 Quad Cab Sport
Color: Mineral Gray
Rep:86
Brutus will become famous soon enough
I'm a little confused on which JL Cleansweep I'm gonna need.
for now i'm gonna keep the factory radio. in the future i plan to upgrade to the factory nav unit.
i'm gonna replace all the door speakers w/ aftermarket.
also gonna add a fox box.
everything will be powered from a 5ch amp for now.
i'm also gonna run all new wire to the doors.
i just need to know what i need between the factory head unit and the amp.
CL-RLC
CL-SSI
CL-SES
CL-441dsp
thanks
2006 Hemi Ram QC 4x4
2000 AF RC Dak R/T
2000 BW CC Dak R/T
  #746
Old 12-31-2011, 05:09 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
I think you need the CL-441DSP and the CL-SSI. Call your local JL dealer and ask to make sure.
  #747
Old 12-31-2011, 06:00 PM
Brutus's Avatar
Color: Mineral Gray
Rep:86
a nice diagram would be nice to have. i'll see if i can find one...
2000 AF RC Dak R/T
2000 BW CC Dak R/T
  #748
Old 12-31-2011, 06:46 PM
Brutus's Avatar
Color: Mineral Gray
Rep:86
looks like i can just use the CL-441dsp. would i just split the rear output to get my signal for the sub amp?
http://mediacdn.shopatron.com/media/...pdf?1316036532
-OR-
just the CL-SSI with 3 of these Kicker ZISL (09ZISL)?
2000 AF RC Dak R/T
2000 BW CC Dak R/T
  #749
Old 12-31-2011, 10:42 PM
Rep:47
I believe that you need the SSI to get the full range of 3 signals. These trucks do not have full range going through just one speaker.
  #750
Old 12-31-2011, 10:47 PM
bigred0311's Avatar
bigred0311 bigred0311 is offline
Vehicle: 2010 Ram Crew Cab 2wd
Trim Level: Big Horn Edition
Color: Off White
Rep:50
bigred0311 will become famous soon enough
i have a 2010 ram 1500 and i just bought 2 10 inch jl audio w'3 4ohm, and a jl audio 500/1v2 amp... but i need a box to go under the back seat..... should i get a custom one or does anyone offer a fitted box already that is reliable?
My Build Thread- http://ramforumz.com/showthread.php?p=781468#post781468
Closed Thread
