Have Audio Questions? We've Got Answers! - Page 76 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Closed Thread
Old 12-31-2011, 10:51 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Fox box is your solution. Also need to trade that 500/1 for a 1000/1 and push those w3's.
Old 01-01-2012, 04:20 PM
bigred0311's Avatar
bigred0311 bigred0311 is offline
Vehicle: 2010 Ram Crew Cab 2wd
Trim Level: Big Horn Edition
Color: Off White
Rep:50
bigred0311 will become famous soon enough
hmmmmnnnn..... JL Audio Slash v2 500/1v2 thats the amp i have to power my w3's. i figured that would be enough and depending which door speakers i eventually get i will run them off a seperate amp..... still think i need a 1000/1 ... im not the best at audio.. pretty new to it actually. thanks for your help.
My Build Thread- http://ramforumz.com/showthread.php?p=781468#post781468
  #753
Old 01-01-2012, 06:05 PM
Rep:47
You don't NEED a bigger amp but it will power them to the full potential.
  #754
Old 01-01-2012, 06:17 PM
bigred0311's Avatar
Color: Off White
Rep:50
i will consider it! thanks for the help and advice!
  #755
Old 01-04-2012, 01:53 AM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
hey guys, this is going to be my first time taking on some wiring in my truck. planning on putting two of these subs
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
and one of these amps
http://www.amazon.com/Pyramid-PB717X...d_bxgy_e_img_c
using this wiring kit
http://www.amazon.com/KIT-2-Complete...d_bxgy_e_img_b
I was wondering if I could get some kind of instructions as to which wires go where, if the power levels, amp fits subs, all go together, etc. also wondering what will need grounding. Thanks in advance, hope someone can help me. lol
  #756
Old 01-07-2012, 02:30 AM
galantesghost's Avatar
galantesghost galantesghost is offline
Color: Mineral Gray
galantesghost is on a distinguished road
Not sure how to search this, so I'll just ask...
2012 Reg Cab Express, aftermarket Nav...speaker/sub plan/questions.
I plan on replacing my door speakers with 6.5 components and appropriate amp. My sub plan is something simple...just an 8" or 10" probably just behind the center console area.
My question is, given this setup, would changing the rear speakers be necessary/beneficial? I'm not an audiophile, but if it is worth the $$$ and trouble, I want to look into it.
Many thanks for any advice.
-- sharing Experience, Strength, and Hope...
  #757
Old 01-07-2012, 12:38 PM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
in my 2011 ram if i look at crutchfield for speakers it states that biggest i can use is 6 1/2 .i took my door panel off today and it had a 6x9 behind it. i measured the distance from the window bracket to the area where the speaker mounts. (3 1/16 ) upon checking some 6x9 speakers for mounting depth i determind that depth wise they should fit. is the issue of them not fitting due the cage in the back of the speaker being too wide or am i missing some other info? i see where my dealer has 6x9 kicker speakers that will fit. any help is appreciated .
  #758
Old 01-07-2012, 03:27 PM
Yourself Yourself is offline
Yourself is on a distinguished road
Amp/Speaker RMS delimma:
I have a set of Polk MM6501 in my truck currently running off of an Alpine F300 amp which is rated at 50 RMS. I decided to upgrade to a more powerful amp to to give the Polks closer to their 125 RMS rating. I purchased the Rockford 300-2 which is rated at 75 RMS 4 ohm, 150 RMS 2 ohm. With the 2.7 ohm load of the MM6501's it should be about perfect. However, when I received the amp, the birthsheet has it rated at 117 RMS at 4 ohm, 182 RMS at 2 ohm(normally a good thing to be rated higher). Doing the math at 2.7 ohms, I have the amp putting out about 159 RMS to my speakers rated at 125 RMS. So do I just need to be careful with my volume/gain or should I be looking for a different amp?
  #759
Old 01-08-2012, 11:05 PM
Big Dog 2008 Big Dog 2008 is offline
Vehicle: 08,3500 and 06,1500
Big Dog 2008 is on a distinguished road
Hey there I have an 06 ram 1500 totally stock My kids got me a sirius subscription and there seems to be a glitch in getting it to bootup the sat signal The truck is sat ready
heres my ? are the antennas for the stereo and the sat seperate the rep at sirius tryed 3 times to set the system with no luck Our dealer here in steamboat is ajoke im hesitant to take it to them any help would begreat by the way BlueJet was a great help in getting me to this area of the site
  #760
Old 01-09-2012, 12:46 PM
Default Sattelite Radio Woes
First thing thankyou for your knowledge and input
Itryedto post a ? Dont know where it went
If daniel or jared has a fix or info on why my sat radio wont boot up It would make my new year Hers whats up with my rig 2006 Ram 1500 stock from factory Asfar as i know it is sat ready My kids got me a sirius subscription and for some reason it wont activate The rep at sirius tryed to reset the signal 3 times and it wont take. The stereo was replaced by dealer for cd malfunction every thing else is ok Are the antennas for the unit seperate ie radio and sat Our dealer here in steamboat springs has a bad rep for repairs Thanx again for all and any assistance to the members of a fantastic site Seeya Big Dog 2008
Closed Thread
