Closed Thread
Old 10-02-2010, 11:46 AM
nhegel's Avatar
nhegel nhegel is offline
Vehicle: 2007 Dodge Ram 1500 Mega Cab
Color: Electric Blue Pearl Coat
Rep:31
nhegel is on a distinguished road
Is it better to use front or rear speakers for line input on aftermarket amplifier? Or is there some RCA outs on the head unit? I have the infinity system that has sat radio and 6 disc changer and the overhead dvd system
Old 10-03-2010, 07:35 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Front speakers.
  #73
Old 10-03-2010, 05:46 PM
alhall88 alhall88 is offline
Rep:24
alhall88 is on a distinguished road
Got a couple questions for you audio experts. OK so I decide to upgrade everything except the head unit for now and this is what I did. First my truck is a 2010 ram with the mygig (non nav) and standard 6 speaker system. I had an older but still functioning amp that I decided to use, it's a 600.1 rockford fosgate. I changed all 6 speakers to infinity kappa's/and reference speakers but using the stock amp for the 2 dash speakers only the other 4 are ran with my amp. I also added a 12 " image dynamics sub in a supercrew console box (standard cab truck). So I install everything including the pac audio C2A-CHY2. I will also add that for the sub signal I just split the front channel rca's using rca splitter cables. I'm getting some noise when I turn up the volume from the right rear speaker but I can get it to come and go by playing with the volume knob. Also did I do this correctly? Everything sounds ok but I expected much better. I'm thinking that this pac unit may be most of the issue and understand that a new head unit would eliminate most issues but can I do something else?
  #74
Old 10-03-2010, 05:58 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
What are you powering the mids with?
  #75
Old 10-03-2010, 07:12 PM
Rep:24
Front doors are infinity reference 6x9 and rears are infinity kappa 6x9, 2 front dash speakers are 3.5 infinity reference.
  #76
Old 10-04-2010, 07:20 AM
chithead's Avatar
Rep:2078
Do you know what impedence (ohms) the Kappas are?
  #77
Old 10-04-2010, 06:39 PM
Rep:24
Yes the kappas in the rear are 2ohm, the front door speakers are 4 ohm and the dash speakers running off the head unit are 2 ohm, also the sub is dual 4 ohm wired in parallel for 2 ohm. I also noticed that when I switch the amp to 4 channel mode instead of 6 the speakers sound much better but then of course the sub is almost non existent . Was splitting the front channel for my sub signal using rca cable splitter the way to go?
  #78
Old 10-06-2010, 04:44 PM
rccody816 rccody816 is offline
rccody816 is on a distinguished road
I am wanting to put 3 JLTW5-3 into an 2003 quad cab. Has anyone done this I am hoping someone has so I can build a box for them. I know I'm pushing the limits and may have to mod the back seat but any help would be great
  #79
Old 10-11-2010, 04:23 PM
Trim Level: Custom
Rep:1648
As long as you lowpassed the sub off of the amp or external crossover you will be fine..
  #80
Old 10-11-2010, 04:24 PM
Trim Level: Custom
Rep:1648
You are wanting all 3 under the rear seat? You can put two under there and the third in a console box..
Closed Thread
