Closed Thread
Old 05-31-2012, 03:37 PM
cdhills06 cdhills06 is offline
Vehicle: 2011 dodge ram 1500 sport
Trim Level: sport
Color: red
cdhills06 is on a distinguished road
need help with where to wire headrest tvs to a switched 12v power source and ground. any ideas, just got my ram and not familiar with it.
Old 05-31-2012, 03:56 PM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
First, you can connect your ground wire to any good metal body, frame or structural part... Or you can look for existing ground points under the dash or hood... As far as a switched 12 power source, a good place to start is with a good 12v test light, you can easily check your cabin aux 12v lighter type sockets to see if they are switched or not... Or using your test light check other existing wires under your dash untill you find a good switched hot lead, and then tap into that... Make sure to include a fuse into your new added circuit
So it is written ! So it shall be done!
  #863
Old 06-02-2012, 02:46 AM
yashew yashew is offline
Vehicle: 2003 dodge ram
yashew is on a distinguished road
I have a 2003 dodge ram 1500 4 dr. i want to replace the back speakers but cant find where or what brackets for new speakers. Could i use the bracket on there or where could i get a new bracket? also any other suggestions for it?
  #864
Old 06-02-2012, 04:24 AM
richard richard is offline
Vehicle: 2012 dodge ram 1500
Color: metal silver
richard is on a distinguished road
hello mr i am new to this forum and I just bought a DODGE RAM 1500 SPORT quad cab with uconnect system Radio audio system 430 with alpine would like to know where is located the factory amolificador or where I can get the diagrams that car audio please
  #865
Old 06-04-2012, 04:28 PM
yodahog's Avatar
yodahog yodahog is offline
Vehicle: 2011 Dodge Ram
Trim Level: 4x4 CrewCab Sport
Rep:21
yodahog is on a distinguished road
Can you use the factory Alpine sub wiring to hook up the PAC SOEM-T?
  #866
Old 06-06-2012, 12:14 AM
micahrojas micahrojas is offline
Vehicle: 2006 Dodge Ram 1500
Color: white/grey trim
micahrojas is on a distinguished road
I have been hearing some people on here talk about changing the bezel to accommodate a double din stereo, i have a 2006 dodge ram 1500 slt with the standard stereo, is all i have to do is change my bezel with the one that is used with the navigation and i can install a double din, i wanted to install a clarion cx501
  #867
Old 06-06-2012, 01:48 AM
Big Red Big Red is offline
Rep:58
Big Red will become famous soon enough
I just installed an OEM 2008 RDS navigation HU. How can I play DVDs on it?
  #868
Old 06-12-2012, 09:23 PM
buddyleewv buddyleewv is offline
Vehicle: 2012 Dodge Ram Quad Cab
Trim Level: Tradesman
Color: True blue
Rep:30
buddyleewv is on a distinguished road
I am another question on my 2012 Ram with the non alpine pain old radio do i need to cut on the bezel or get a new on to install a double din nav unit. I looked at the specs on the radio and it says its 4" tall and the opening is right at 4". I've looked online for nav bezels with no luck they are all for older trucks.
  #869
Old 06-14-2012, 06:03 PM
08blackbighorn's Avatar
08blackbighorn 08blackbighorn is offline
Vehicle: 2008 dodge ram 1500 bighorn
Trim Level: quad cab
08blackbighorn is on a distinguished road
hello just wondering i got a 2008 qc ram 1500 with 4 speakers but spots for the 3 in the dash is the wiring there for all 7 or anyway i could run wires to them thanks and sorry if i missed it being asked before
  #870
Old 06-18-2012, 12:40 PM
Bumpydog Bumpydog is offline
Vehicle: 2005 Dodge Ram 1500 Hemi 4WD
Bumpydog is on a distinguished road
Default Replacement for 2004/5 QC w/Infinity
I am looking to bypass the factory amp and replace all the speakers. I'll also fit an aftermarket double-din head unit at the same time. What is the consensus on a good speaker/amp setup? I am based in Europe.
Closed Thread
