tonneaucovered.com
Closed Thread
Old 10-08-2012, 02:22 PM
AlexZ AlexZ is offline
Vehicle: 2012 Ram 1500 Crew Sport
Color: Deep Cherry
AlexZ is on a distinguished road
Default VES Issue
DVD's won't show on the rear screen. Am I doing something wrong?
Old 10-10-2012, 12:36 AM
Medic's Avatar
Medic Medic is offline
Vehicle: 2007 Ram + 1969 Dart
Color: Electric blue
Rep:15
Medic is on a distinguished road
Default No rear speakers with aftermarket deck in 2007 with Infinity
Installed my new JVC deck and suddenly I don't have any rear speakers. 2007 with the Infinity system. Before you ask, yes I did connect the blue amp wire. However I did connect my antenna power wire to the same place. Done that before without issue. Everything else is hooked up exactly as it should be. Speakers are fine, everything worked before the switch. Any thoughts? Thanks in advance!
(And apologies if this has been answered before, the forum search yielded no results for me, and this is a very long thread!)
Yea... It's got a Hemi.
  #913
Old 10-14-2012, 08:00 AM
hockeybro43 hockeybro43 is offline
Vehicle: 2008 dodge ram
hockeybro43 is on a distinguished road
i just got a 2006 1500 QC. going from the single din to double with nav. in order for the nav to work do i have to do anything special or just mount that small box somewhere. also will the factory speakers last with a better head unit? dnx6190hd thats the kenwood i plan on getting. thanks for your help. any other suggestions are welcome.
  #914
Old 10-16-2012, 03:03 PM
aBlackguyWITHaTRUCK's Avatar
aBlackguyWITHaTRUCK aBlackguyWITHaTRUCK is offline
Vehicle: 2003 dodge ram
aBlackguyWITHaTRUCK is on a distinguished road
Ok here the deal I have a rockford fosgate p3s punch....but im looking for something that handle AT LEAST 600w RMS. Ive seen that kicker has a the L7 & the L3 with truck box enclosures. Any input?
  #915
Old 10-16-2012, 07:12 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
What a speaker will handle power wise has very little to do with the speaker itself. The type of enclosure and how clean the power is will greatly affect things.
I've put 1500 clean watts into drivers rated for 500 max with zero issues.
For a sub you can get away with a lot more with small, sealed enclosures. Ported enclosures will take less power given the same driver.
My suggestion is to stop looking at RMS ratings and focus more on the install.
  #916
Old 10-23-2012, 01:54 PM
shears's Avatar
shears shears is offline
Vehicle: 2009 Dodge Ram 1500 Sport
Rep:47
shears is on a distinguished road
Coming up pretty soon I want to purchase a double-din in-dash head unit. I want built-in GPS, rear usb connectivity for my ipod and a usb thumb drive. also want builtin satelite radio since I have the stock satelite antenna and cabling in place already. what is a good brand and model I should look into? I want a nice unit but don't want to spend more than $700. any help is appreciated.
6" BDS Lift, 35x12.50x18 Nitto Trail Grapplers, 18x9 XD Addicts, FlowMaster Super 10, S&B Cold Air Intake, Solar Gard 20% window tint, WeatherTech DigitalFit floor mats, Debadged, Plasti-Dipped Grill and rear ram head emblem, Tow hooks
Taking Donations for more mods...
  #917
Old 10-28-2012, 06:18 PM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
What size would the speakers be on the dash in the 2011 Ram 1500 ST 4x4? Looks like a 2.5" or 3" speaker size or so. I am going to replace all my speakers with some of the higher end pioneer speakers all the way around but the sub. I need a box for the rear and am going to put a single 10" or maybe a 12" as well. I thought about dual 10's or 12's but I think a single would be better so I have a bit of space on the other side of the rear seat still. I believe the fronts are 6x9 and rear speakers are 5.25" according to sonicelectronix.com but they said nothing about the dash speakers. Any help would be awesome.
-C
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
  #918
Old 10-28-2012, 06:59 PM
kozzy kozzy is offline
Vehicle: 2016 Ram 3500 Big Horn
Color: Delmonico Red
Engine: 2016-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 900lb/ft (Aisin ASC69RC Automatic)
kozzy is on a distinguished road
Anyone ever mount an amplifier under the center console of the Rams? I have a 2102 2500 and I was thinking right under that center console, in the front would be a sweet spot. protected, and very easy to run all the wires. Im not running subs, just the 4 door speakers, so I would not think it will get too hot in there, but my only concern would be heat becsasue it is enclosed.
Thoughts?
  #919
Old 10-28-2012, 07:05 PM
-C
My 2011 1500 outdoorsman , i put all JL Audio in it, the dash I used the c2-350x which were 3.5" and they were a perfect fit. Factor for all doors are 6 x9". In my front doors, I used 5 1/4" with an adapter to fit the 6 x9 opening, and in my rear doors I used 6 x9 speakers, all fit perfectly, and sounded great. i took all the equipment out to put in my new 2012 2500, only thing i might change is i might put the 6x9 in the front and the 5 1/4 in the back..good luck
  #920
Old 10-28-2012, 07:12 PM
I put a Kenwood DNX 6960 in mine. I liked it because it uses Garmin for the navigation. It has all the features you are looking for except I think there is a seperate module you have to buy for Sat radio. The rear USB is on a wire and nice, comes with a bracket so you can add the plug to your dash board if you want. I just ran the wire to my glove box and leave my USB drive hooked up in there, out of the way and easy to get to. I did have to do some modifing to my sub dash, had to cut a piece of plastic out, and bend one of the metal bars. Used a dremel tool for it, was quick, easy, clean, and still maintained the size for me to put all the factory stuff back in this past weekend. All in alkl, it has been a great unit. Not sure if they still make that model, since mine is over a year old, but im sure they have a replacement. price was 799 on sale at crutchfield, normally it was 999, and has a 2 year warantee. I looked for a long time, and the kenwood seemd to have the most features, good nav for a good price. Very easy to add a backup cam to it also.
Closed Thread
