Closed Thread
Old 11-24-2012, 02:31 PM
Vehicle: 2012 Dodge Ram Sport
Rep:47
Originally Posted by Zoomin0074 View Post
I am looking to make my sound better in 2006 quad cab 4 speakers.. What would be better to start with new Double Din head unit with stock speakers or new speakers with stock head unit.. I was thinking of just replacing the speakers first with some Polk audio's..
You could either way you wanted really.
Old 11-24-2012, 09:57 PM
JMK JMK is offline
Vehicle: 2011 Dodge Ram 1500
Color: Two tone Blue w/gold trim
JMK is on a distinguished road
Can i install a larger woofer than the stock one on my 2011 laramie without adding a separate amp?
  #943
Old 11-25-2012, 05:07 AM
Rep:47
If you are wanting more bass the. You will need to remove the old sub and get a new box, sub, amp, and a way to run it with your stock stereo. If your not looking for a lot of bass just a little more I would do a single side box with a 10" sub. It wouldn't be that much.
  #944
Old 11-25-2012, 07:59 PM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
So I have a question on spacers. I got some pioneer 6x9's that I knew wouldn't fit but the spacers won't either. What spacers for the front 6x9's have you guys used or what speakers would you go with? I'd like to use the factory place, but I'll do what I have to.
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
  #945
Old 11-26-2012, 09:10 PM
bamaboy1626 bamaboy1626 is offline
Vehicle: 2010 Ram Sport
Trim Level: sport 2WD
Color: silver
Rep:20
bamaboy1626 is on a distinguished road
piggy backing on the question above.... I want to use the factory spot, and my search had yeilded nothing that will fit right in the factory spot. I guess I'm just being lazy but I want something that I can swap out quickly. My stock ones are shot and sound like shiznit.
  #946
Old 11-27-2012, 12:21 AM
InDeepWaterBlue's Avatar
Rep:611
Why did you get 6x9's if you knew they weren't going to fit? There's nothing wrong with the front sized speakers because you also have them in the dash. if you're looking for more bass response you need to upgrade the factory sub, it does a decent job but a single 10" provides a much better sound. If you are looking for better highs and mids consider replacing the Head Unit, I replaced the stock Alpine with a Double Din pioneer with a highly adjustable EQ.
As far as making them fit with an adapter I haven't come across one that fits propery, you could always just make the opening bigger yourself which means a bit of cutting and drilling
  #947
Old 12-01-2012, 11:51 AM
evan501 evan501 is offline
Vehicle: 2009 dodge ram 1500 trx4
Trim Level: Trx4
evan501 is on a distinguished road
Default Kicker 10" cvt question
I have a 09 trx4 crew cab & was wondering can I put in 2 kicker 10"cvt with a atrend box or pro box under the seat. Or do i have to go with the kicker 10" cvr shallow mount? If you recommend other boxes I'm open to your opinion.
  #948
Old 12-02-2012, 03:57 AM
Jolley's Avatar
Jolley Jolley is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Color: Tan Pearlcoat
Rep:33
Jolley is on a distinguished road
Hey guys I have a 2010 Laramie with the alpine 8" sub under the back seat, I'm wanting to replace it with a 12 or keep it and put a 12 alOng side it in the storage bin on the other side, my question is can I keep the stock alpine amp to run both the 8 and the 12 or just the 12
10' Laramie/35 Mud Grapps/Wheel Spacers/Level/Straights w/ 4" tips/8K HIDs/Bull Bar/22" Led Bar
  #949
Old 12-02-2012, 09:18 AM
Rep:611
I think you're better off just running the single 12. When you get the 12 you'll need another Amp anyhow and the 12 will just over power any sound you'll get from the small 8
  #950
Old 12-19-2012, 07:02 PM
Jolley's Avatar
Rep:33
well i went ahead and ditched the factory 8" sub and got me a 10" boss sub in a box that fits where the factory box was, i haver a amp and i have everything wired to it and all the wires are hidden, my question is which wires on the back of the uconnect radio do i tie the input wires from the amp into, and which wire do i tie the remote wire into, ive been trying to find some kind of diagram of the headubit but cant find one
Closed Thread
