Closed Thread
Old 02-22-2013, 05:12 PM
twmotox's Avatar
twmotox twmotox is offline
Vehicle: 2003 Dodge Ram
twmotox is on a distinguished road
Default ptt
I am installing a kenwood 8890 in my 2012 ram. I know this is a stupid question but what is the purpose of the PTT button? Also there is a wire marked mute coming out of the HU. Wouldnt that already be taken care of through my installation and I just leave that wire alone? Thanks Tony
Old 02-23-2013, 03:26 AM
InDeepWaterBlue's Avatar
Rep:611
check what the wiring book from your radio says to connect it to. Some radios require a mute button wired into another wire to work properly.
  #973
Old 02-24-2013, 05:53 PM
ringmic ringmic is offline
Vehicle: 2001 Dodge Ram 2500
ringmic is on a distinguished road
Default left speakers do not work
I just bought a 2001 Dodge Ram 2500 and it looks to have the stock stereo speaker package. I can only get the right side speakers to work. No sound from the left side speakers...front or back.
I would be grateful for any advice
Also....I have a plow on the truck and when I actuate any movement of the plow the radio goes out until I stop the plow movement.
  #974
Old 02-28-2013, 09:34 PM
wickwire wickwire is offline
Vehicle: 2010 dodge ram
Trim Level: laramie
wickwire is on a distinguished road
Default Adding amp and subs to 2010 with Alpine system
Good evening to all. I am adding the jl audio stealth box and a rockford 1500 amp to my 2010 ram with the alpine system. Trying to tap into stock system with loc. I got an amp diagram from crutchfield for the stock amp. The wire colors on the diagram dont match the wires actually in the harness for the door speakers. Cant find the LR (-) GY/LGR, the LR(+)GY/GR, or the RR(-)GN/LGR. I found a grey with pink stripe, a grey with a black stripe. Any info appreciated.
  #975
Old 03-01-2013, 08:01 AM
Excoastie's Avatar
Vehicle: 2016 Jeep Wrangler
Trim Level: Rubicon Hard Rock
Color: Hydro Blue
Rep:1358
Here what might be considered a stupid question. I've done some searching, and some more reading through this thread. I didn't find my answers..
I've got the stock Alpine system, with the basic head unit set up (I can never remember the code LOL).
I've been contemplating upgrading to something aftermarket. Do I need to worry about everything working, or other problems that are associated with the Alpine system? I've heard in past years that the Infinity was hell when installing an aftermarket system.
I'm assuming (Yeah I know what happens) that there are wiring harnesses available for both the OEM harness, and another for the steering wheel controls. (I'll probably go with a Pioneer or Kenwood head unit if I actually do more than talk)
thanks for your help
Exco
Bill
  #976
Old 03-01-2013, 09:02 AM
Rep:611
Exco
You don't read my build thread much do you There are seperate harness' for the steering wheel controls as well as the audio harness. I went from the standard CD player radio to a Double Din Pioneer AVH-P8400BH. Not the easiest of installs but well worth it IMO. The problem with upgrading from the factory single Din to the Double Din is that there's a pesky support brace in the way that has to be hacked out, and then you have to modify the bracket adapters and opening just a little bit for it to fit properly. The Harness for the Radio I got from PAC works great, just match up the colors on the wires and your done. As for the steering wheel controls.... I got lazy the harness is still siting in my tool box. I got impatient waiting for 3 days (because I painted the console bits) to have a radio again, so Iput it all together without the harness.
  #977
Old 03-02-2013, 09:15 AM
Excoastie's Avatar
Color: Hydro Blue
Rep:1358
I must admit, no I don't read much in the way of build threads. You can chock it up to my laziness LOL.
Thanks for the info. It sound to me like it might too much trouble to try to go with anything that is double din (it goes back to the laziness thing). I may look into something that is single din, and then decide from there.
What I'm really wanting is something that has a hard drive, but is also affordable (~$200-$300). I don't believe that such an animal exists, but there are many that will play MP3s through a USB, which is also acceptable to me.
I'll find something. I haven't truly decided that I even want to upgrade, as once the head unit gets upgraded, it leads to speakers, amps, etc..
Exco
Bill
  #978
Old 03-02-2013, 09:32 AM
rango88's Avatar
rango88 rango88 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:18
rango88 is on a distinguished road
I currently Have the base 6 speaker stereo in my Ram and I have Infiniti 6 1/2 Round speakers and Infiniti Type R 5x8. I was just wondering if the Base head unit could supply enough power to those speakers without an aftermarket Amp
Infiniti are 65 watts RMS
Alpine are 50 Watts RMS
Also will these speakers fit in the OEM door area (Infiniti in the front and Alpines in the back?)
Andy ***Cannot see all Pics and Videos***
  #979
Old 03-02-2013, 01:13 PM
Rep:611
base head unit can handle the door speakers just fine, as for fitment if they're the same size as factory you won't have an issue. The only thing you won't know until you install them is how deep the speaker is, and sometimes (though rarely) a spacer need to be put installed with the speaker.
  #980
Old 03-02-2013, 01:17 PM
Rep:611
Exco
You'd be amazed how much the stock Alpine system sounds with an upgraded stereo. The Pioneer I have has a nice adjustable EQ and I think the speakers are great. Mids and highs are much crisper. I'm sure there's a couple options out there for you, there's a few radios that take memory sticks that you can load up with songs, and the memory stick itself is behind the face plate so you'd ever see it. I don't blame you for being lazy, it's the reason mypost count is still so low in comparison to others that joined around the same time I did And installing a double DIN into the base location definitely isn't for someone who doesn't want to work hahaa
Closed Thread
