Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 09-03-2010, 10:21 PM
dougcolburn dougcolburn is offline
dougcolburn is on a distinguished road
Default front end noise
I have a 2003 4x4 5.7 ram, in the past year i have had to have the hub and wheel bearings replaced2 times in the past year on both sides, has only 86000 miles on it i purchased the truck used 2 years ago, it is making a grinding/growling sound again but sounds like it may becoming from front drive shaft, anybody else ever had this problem?
Old 09-03-2010, 10:24 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
U-joints, transfer case, front differential.
Has the transfer case and differential oil been replaced? How are the levels? Any leaks?
Welcome to the Z.
We have a lot of forums for all kinds of topics, so you shouldn't have any problems finding a place to post questions.
We LOVE pics of Rams.
Here's how to post them: http://www.ramforumz.com/forumdisplay.php?f=73
Brian:
Old 09-03-2010, 10:27 PM
Thats unusual to hear of wheel bearing failure like that . They should last well over 100,00 miles . When the wheel bearings were replaced , was the axle nut torqued to spec or hammered tight with a air gun ?
Old 09-04-2010, 05:46 PM
so i pulled the front drive shaft and the noise is gone. put back on and have the noise again. checked the fluid level in the transfer case and front diff both full so what is my next choose???
Old 09-04-2010, 05:50 PM
Color: RootBeer
Rep:1287
take the drive shaft off again and turn the caps on the u-joints by hand. if they are hard to turn or feel like they are grinding, that's your problem. replace the whole join, don't try to save a penny or two by just getting new bearings and caps.
Brian:
