Old 09-04-2010, 01:16 PM
Redneck24V's Avatar
Redneck24V Redneck24V is offline
Vehicle: 2003 Dodge Ram QC 4x4
Redneck24V is on a distinguished road
Default Cat Delete
I have an 03 Ram Hemi, it already has flows, but I am wanting to do a cat delete and am not sure what needs to be done, do I need to get an o2 simulator or something like that? I dont want my SES light coming on, or can i just cut them out? Any and all info is helpful! Thanks
03 Ram QC 4x4 Hemi 3.55's Bully Dog G/T Flowmaster CAI
Old 09-04-2010, 01:26 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
You have emissions testing/inspection where you live? If you do, you could face a hefty fine.
Brian:
Old 09-04-2010, 01:28 PM
Redneck24V's Avatar
no we sure dont
Old 09-04-2010, 01:54 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
you can buy MIL elimiators or get a custom tuning shop to just turn the O2s off.
Old 09-06-2010, 05:33 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
Or you can try the spark plug anti-fouler trick. Drill out the anti-fouler and install it to the o2 bung then install the o2 sensor. Works on some vehicles (seems to work on more vehicles than not) so its not a guarantee, but Ive used it on other cars and its worked just fine
2015 Camaro 2SS/RS/1LE
Old 09-06-2010, 05:48 PM
ScatPak07's Avatar
Rep:970
If you want you can also get high flow cats. That allows you to keep everything legal and to get much better flow than stock. Thats an idea but you can still delete them with the right instructions. I am not sure how to delete and keep the truck from freaking out, sorry man
Old 09-06-2010, 05:54 PM
I'd replace the cat with some high flow units and keep the sensors. That's the easiest way to avoid getting a sensor code.
One other way is to delete the cat, put in a pipe with a welded/threaded bung and put the sensor back in.
Old 09-06-2010, 06:18 PM
doz doz is offline
Rep:76
If you remove the cat and still have the o2 sensor installed, itll still throw a code Maddog (itll throw the catalyst code as itll read the CC isnt doing its job). You have to spoof it whether the o2 sensor is installed or not (hence the spark plug trick).
Even SOME hi-flow cats will throw a code (I had a set that did on my Grand Prix), so they arent a guarantee, depends upon how sensitive the computer is and how well the hi-flow cat does.
Old 09-06-2010, 06:35 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
apparently it works on my '97. the cat was gutted....and there is an extra 'fitting' on the downstream o2 sensor. it has to be a 'fouler' screwed into the hole, and then the sensor screws into that. No trouble codes for me.
