Old 09-05-2010, 01:32 AM
4pnt7 4pnt7 is offline
Vehicle: 2008 4.7l Dodge Ram
Color: Graphite Grey
4pnt7 is on a distinguished road
How is it at idle? How is it when cruising? Is it at part/wot?
Nicolas Chavez
2002 ram 4.7l qc (Totaled),60ft.-2.0,1/8-9.310,@76.mph,1/8-9.41,1/4-14.80,@90.94
Old 09-05-2010, 01:57 AM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
If you pull both battery cables and touch them it'll ground out the system and reset immediately. Just make sure you pull both. Touching the hot and cold while it's still hooked up with cause a catastrophic short.
After reset try doing some hard starts (read as WOT) and then some cruising to fill those adaptive tables back out.
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 09-05-2010, 02:09 AM
BigOrange BigOrange is offline
Vehicle: 2013 RAM 1500
Trim Level: EXPRESS QUAD CAB
Color: BRIGHT SILVER
Rep:17
BigOrange is on a distinguished road
it idles fine, & cruises fine, it's under WOT that it sound and feels rough, and say when I'm cruising at 40 and I want to ease up to highway speeds, it's a little choppy there too.
Magnaflow 14" SI/DO, No Resonators, K&N Drop-In Filter, De-badged.
Old 09-05-2010, 02:46 AM
Give me a call if you want. Its easier to explain on the phone.
After you reset your computer you want to take it easy so your computer learns. You start off at light throttle and work your way up to wot.
Nicolas Chavez
Old 09-05-2010, 03:08 AM
What are hard starts?
Nicolas Chavez
Old 09-05-2010, 03:40 AM
Rep:17
I took it as flooring it from a stand still a.k.a. going W.O.T.
Old 09-05-2010, 03:46 AM
Rep:17
so to reset the ecm by the fuse pulling method, do I just pull out the ecm fuse and put it back in? Also, is it in the fuse box by the battery?
Old 09-05-2010, 04:48 AM
Yes its by the battery. Pull the fuse, turn key to on position. Turn off, put fuse back on. Start truck and let computer find idle before driving.
Nicolas Chavez
Old 09-05-2010, 10:23 AM
GPSHSLAX's Avatar
Trim Level: ST 2X4
Rep:236
That's exactly what I meant (thus the read as WOT comment). I point is that after reseting the computer needs to relearn cruising behaviour as wel as what to do when you get on it.
Old 09-05-2010, 11:44 PM
Rep:17
Update: Well, the truck is back to running normal with the Airaid intake tube into the factory airbox with a K&N drop in filter. I did put on a new IAT snesor with the cone filter setup, and it still ran poorly. I guess my computer just didn't like all the extra airflow??? This was just a weird circumstance!
Anyways, I'm still happy with the Airaid intake tube, and the truck still looks, sounds, and performs great!!!
Thanks for all the replies!
