Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - News Desk > Newbie Checkin!
Newbie Checkin! New to the forums? Introduce yourself here!
View Poll Results: Should I upgrade from 3.55 to 3.92 rear if towing camper trailer with new 2011 Hemi
No 0 0%
Yes 8 100.00%
Voters: 8. You may not vote on this poll
Old 09-05-2010, 01:05 PM
postman postman is offline
postman is on a distinguished road
Default Rear axle ratio choice on 2011 Ram Hemi
Will be ordering a new 2011 Ram 5.7 Hemi shortly. I will be towing a medium sized 28' camper with this truck as well as a fully loaded snobile trailer. It comes with the standard 3.55 rear ratio, should I upgrade to the 3.92 rear ratio and if I do, what would be the gas mileage difference on average.
Old 09-05-2010, 01:09 PM
Not sure what the mpg difference would be...that's really a function of the driver. How much does your trailer weigh?
Welcome to the forum. Take a few moments and introduce yourself in the Newbie Section.
Old 09-05-2010, 01:15 PM
The camper trailer is about 4500 lbs with another 1000 plus pounds allowed for load capacity.
Old 09-05-2010, 01:17 PM
I'd go with the 3.92 for better towing power as a 3.92 is a taller gear which will provide for better low end torque.
The 3.55 will work as well, it will just be lower out of the hole.
Will you be towing a lot? Will you be towing other loads?
Old 09-05-2010, 01:44 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Along with better towing response the 3.92 gears are limited slip which will be better for snowy roads.
Brian:
Old 09-05-2010, 01:46 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
I would say 3.92, the mpg difference is very small, you can easily make it back up by a couple simple mods to increse airflow to the engine.
Old 09-05-2010, 02:07 PM
Rep:2705
welcome to this ForumZ from San Diego
if i were going to be towing much, or using the truck to haul a bed full, or live where there will be hills, or less than perfect climate, i'd go with the 3:92 ratio
i would also be checking out the 2500 series trucks for several reasons.
a 1500 series comes with non pulling gears as standard, 3.92 are an option
2500 series have 3.92 as standard, its just a bit heavier & from what i have seen on here, the mileage is within 1 mile per gallon of the lighter truck.
remember the 2009 - 2011 trucks are all the same design, the only thing different are minor things, like a locking tailgate, radio types, brake controller, etc
the 2012 will be a different body style & possibly a bigger engine as an option
Old 09-05-2010, 02:11 PM
Color: RootBeer
Rep:1287
All excellent points.
Brian:
Old 09-05-2010, 11:39 PM
Rep:1625
Welcome to the forum postman!
Old 09-06-2010, 12:44 AM
iRESQu iRESQu is offline
Rep:2217
Hello and welcome aboard the ForumZ. Great to have you!
