Old 09-08-2010, 12:27 PM
Vectors2Final Vectors2Final is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
Vectors2Final is on a distinguished road
Aww, shit looks like I might get a set.
Old 09-08-2010, 11:38 PM
09 RT RAM's Avatar
09 RT RAM 09 RT RAM is offline
Rep:39
09 RT RAM is on a distinguished road
Talking
Originally Posted by SPEEDFREAK View Post
Use the stock shocks! The bilstines are not valved right for being lowered. Iam in the process of sending them back and getting them revalved. Not enough damping when at highway speeds and going over bumps. The front end will floot
I have run everything from highly modified Z28's to BMW's the last 35 years. This truck has zero float. The handling is good. Now.....you want to tune them go HAL QA1 billet 12-way adjustables. www.ruslow.com hooked me up years ago for the 2000 Ford Lightning.
SPEEDFREAK...did you mount the Addco's? The bars with tighten it up tremendously. I tried them with and without the Addco bars.
Here is some help for those who want a custom adjustable set up. HAL QA1. Stocker Star® - Single and Double Adjustable Stock Mount Shocks.
John,
It is much easier if you give us a call. The best person to speak with is Mike. The number is 916-771-0109. We will need to know your installed height and upper and lower mounts.
DTC1540P Stocker Star® Double Adjustable Single Adjustable
Double Adjustable 10.25 Inch 15.50 Inch Stud T-bar $329.00
DTC1914P Stocker Star® Double Adjustable Single Adjustable
Double Adjustable 8.75 Inch 13.50 Inch Stud T-bar $329.00
DTC1958P Stocker Star® Double Adjustable Single Adjustable
Double Adjustable 9.38 Inch 14.38 Inch Stud T-bar $329.00
Every QA1 double adjustable shock features 24 positions of compression adjustment and 24 positions of rebound adjustment, providing 576 possible combinations to maximize the performance of your vehicle. There are three features that are critical for an excellent double adjustable:
1. Adjustment Range
QA1’s adjustment range encompasses virtually every application
2. Tuning ability within the adjustment range
QA1 offers evenly spaced valving changes throughout the adjustment range. There are no “jumps” when adjusting between any two clicks.
3. Independence of compression & rebound adjustments
QA1 has developed a truly independent double adjustable shock. When the compression knob is adjusted, rebound does not change and vice versa. Compression and rebound are controlled independently, allowing the ultimate in fine-tuning for any application. Most manufacturers of double adjustables make this same claim – however, they cannot necessarily back it up with the product. We strongly encourage serious racers and performance enthusiasts to put their double adjustables to the test on a dyno. We are confident that you will find that there is no comparison between QA1 and the competition.
QA1 offers the double adjustable shock for a variety of applications, including stock suspensions for 1955 – present American cars and light trucks, front coil-over conversions for GM muscle cars, as well as four-link and ladder bar type suspensions. The double adjustable shocks are available in the Proma Star®, Stocker Star®, Pro Coil, Corvette “C”, Generation “F”, Pro Street and Mustang Rear series.
Double Adjustable Truly Independent Compression and Rebound Adjustment
576 Valving Options
Includes 24 positions of compression adjustment on one knob, and 24 positions of rebound adjustment on the other knob. Each knob is clearly labeled with an “R” for rebound or a “C” for compression, as well as plus and minus symbols for ease of adjustment.
· Some front applications may require the lower a-arm to be dropped for installation. Body diameter may be too large to allow mounting from the bottom. Some control arms’ shock openings may need to be enlarged to accept a QA1 shock.
· Due to deviations from the factory ride heights, it may be necessary to check the actual ride height of your particular application.
· Many Stocker Stars® can be converted to different mounting applications.
· If you do not see your applications listed, please call the QA1 tech line at 952-985-5675 for more information
Out the door to work. HAL will manufacture them custom length. I am ordering a full set similar to those I had on the Lightning.
Old 09-09-2010, 10:54 PM
09 RT RAM's Avatar
Rep:39
Talking
Originally Posted by chithead View Post
I think his were from eBay, ordered my SRT-10 replicas from OE Wheels.
yea, ebay.....had them powdercoated Electric Fusion in Hurst, TX.
Old 09-09-2010, 10:58 PM
09 RT RAM's Avatar
Rep:39
Talking
Originally Posted by BeBeep View Post
I sure would love to get a ride in your truck to see how the lowering and new sway bars effect the ride. I know you are a very busy guy but if you ever get some free time, give me a hollar. I would meet wherever to check it out.
no problem....very busy with all these peeps on the internet trying to keep it up and running at a very high level......pm coming.....
p.s...NO comment on the HK 9MM? What a bunch of wimps!!!
Old 09-10-2010, 10:40 PM
BeBeep's Avatar
BeBeep BeBeep is offline
Vehicle: 2010 Ram
Trim Level: R/T
Rep:16
BeBeep is on a distinguished road
It is an HK, what more is there to say? Maybe tell the criminals to smile and wait for the flash!!
2010 Ram R/T - 2011 GWE Challenger SRT8
Old 09-10-2010, 11:29 PM
Looks great .
Old 09-11-2010, 10:54 PM
09 RT RAM's Avatar
Rep:39
Talking
Originally Posted by Toms Blue Ram 1500 View Post
Looks great .
the truck or the gun?
truck to get paint correction very soon.........almost 22,000 miles.........BATTLE SCARS! Check the front bumper.........bhahahaha
Old 09-13-2010, 07:42 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Your truck looks fantastic..............saweet
Old 09-14-2010, 09:32 PM
09 RT RAM's Avatar
Rep:39
Lightbulb
thanks...it is a daily driver......it has about 12 dent doctor dents in in believe it or not small hole in front bumper etc. Dallas highways, major suckage with debris.......
this truck is a road warrior and will not be a garage queen.......
my buddy paints and will slick this one out for 2500.00...not bad considering the hood that he painted blows away the rest of the factory paint..........the factory paint guns were a little dry and it shows a bit too much peel. But once it gets krapped out I will just spray the whole gig. Lifetime Warranty......might as well use it.
Old 09-14-2010, 09:44 PM
09 RT RAM's Avatar
Rep:39
no time to finish this truck up soon........ordering headers today to be sent out for drop shipped coating (i hope or might use them raw???) ......the whole wrap up is killing me. My garage is looking like a dang speed shop. Guy at work has Dynatech Stainless long tubes on his 3rd GEN and he tells me I am crazy to coat them. So I am on the fence with coatinng now.
