Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Place your Ad Here!
Old 09-05-2010, 06:42 PM
littlelouie46 littlelouie46 is offline
littlelouie46 is on a distinguished road
Default no throttle
one problem that i have is that i will lose my throttle at times for sec. and that my tcc will jump on and off i had herad that it could be my tps sensor and that there is a bullinten on the sensor is there anyone that is having the same problem. and what did they do to fix it?
Old 09-06-2010, 12:10 PM
Resident Technician
Rep:1915
Need more specific info such as the exact year and model of your truck. Do you have the standard or HO CTD?
Old 09-07-2010, 08:05 PM
i have a 2001 dodge ram 2500 diesel 24 valve High output it is 4x4 and is automatic tranny.
Old 12-07-2010, 11:17 PM
kb9lsv kb9lsv is offline
Vehicle: 2001 2500 cummins, 1998 ram v6
kb9lsv is on a distinguished road
use the key trick and pull codes, likely either tps or vp. tps can be reset and that could be the fix, or could be a dead pedal issue caused by the vp going bad.
Old 12-14-2010, 02:00 AM
jd322 jd322 is offline
Vehicle: 99 24v ctd
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
jd322 is on a distinguished road
Sounds like the apps/tps just above the injection pump should have a black cover over it with a cable coming out of it. You can check the sensor with a meter and see if it has any dead spots. But should of tripped the ce light. Takes about 5min to replace the senor. Problem is the are not cheap.
