Old 09-05-2010, 09:36 PM
St. Ram's Avatar
St. Ram St. Ram is offline
Vehicle: 1997 Dodge Ram
Trim Level: SLT Laramie
St. Ram is on a distinguished road
Exclamation Engine issue
I am having trouble with my engine. It starts but won't stay on unless I hold the pedal down. I have researched this issue and keep hearing about "vacuum leaks" but I must confess, I am NOT a mechanic and don't know where to start looking for this issue. Can anyone help with this...preferably with pics? I can't afford to go to a mechanic right now and it doesn't sound difficult. I could probably fix it if I just knew what I was doing or at least where to start.
Old 09-06-2010, 12:21 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Real basic, just start tracking all hoses coming out of the throttle body. Look for any disconnected hoses, cracks, splits, etc. Do you hear any hissing when it's running? Is it tossing any codes? Try the key dance and see if there are any, and post them up.
Old 09-06-2010, 12:50 PM
Rep:1845
Has the battery been low/dead lately? If so, the PCM needs to relearn the idle strategy. A dirty throttle body can also cause this problem.
Old 09-06-2010, 03:25 PM
St. Ram's Avatar
How about a missing oil filler cap? I didn't see that coming.
Old 09-06-2010, 03:41 PM
Rep:1845
If that cured the problem, you've just uncovered another one. I'm betting you have a plenum pan gasket blown, causing an internal vacuum leak.
Old 09-06-2010, 03:43 PM
sobercrew's Avatar
sobercrew sobercrew is offline
Vehicle: 2003 dodge ram 1500 4x4
Color: silver/chrome
Rep:101
sobercrew will become famous soon enoughsobercrew will become famous soon enough
Send a message via Yahoo to sobercrew Send a message via Skype™ to sobercrew
I would definatly listen to ramtech he is very helpful and gives great advice and definatly knows what he is talking about
NEW SIG PIC YAY
Old 09-06-2010, 04:32 PM
St. Ram's Avatar
OK...I realize this is gonna sound dumb, but what is a plenum pan?
Old 09-06-2010, 04:37 PM
Rep:1845
The plenum pan gasket is on the bottom of the intake and is notorious for blowing out. Are you consuming any oil between oil changes and you aren't sure where it's going?
Old 09-06-2010, 06:46 PM
St. Ram's Avatar
nope. that's not an issue. it has been running fine until now. scratch that, I got an error but it told me I had a misfire in #1 but I changed that and all has been fine. that was about two weeks ago.
Old 09-06-2010, 07:17 PM
Rep:1845
Keep an eye on your oil level for the next little bit just to be sure.
engine, start, vacuum
