Dodge Ram Decals
Old 09-05-2010, 10:47 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Default Wiring cab to bed???
Ok, so I have the CB mount fabbed up, and I am mounting the antennas in the stake holes, but.... I cannot find a grommet to put the antenna wires through to save my life! I have looked behind the seats, under the seats, along the tranny tunnel. There are tons of grommets in the bed, but I can't find one in the cab. Has anyone ran wires out of the cab, either in the floor or the behind the back seat? I am not quite ready to drill holes in my new truck, hence using the stake hole mount for the antennas. PLEASE HELP.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 09-05-2010, 11:12 PM
Rep:1625
You could probably run the coax along the truck to the firewall, entering the cab through a grommet above the brake pedal.
I know this probably doesn't help any, but here's a pic from online:
Old 09-05-2010, 11:31 PM
Rep:4206
Not sure about the 4th gens, I'm not too cool with drilling holes in my truck, either, and I'm not running the dual antenna that I really want, lol, but I have the magnetic antenna, mounting that to the bedrail just behind the cab, I'm looking to run the coax through the drain plug in the back of the bed and into the cab. Like you, that's the problem I am having, locating where I can run that into the cab. Once I figure that out, wiring it is not the problem. I know how to hide the coax, run it under the seat or along the pillar if needed, but you are asking the question I really need an answer to as well!
Old 09-06-2010, 07:52 AM
Resident Technician
Rep:1915
Why not just drill a hole and install your own rubber grommet? If done right, it's just as good as anything the factory can install.
Old 09-06-2010, 09:08 AM
Wildcat's Avatar
Rep:166
I know in my head that this is probably true, but it is a mental thing of drilling a hole in my new truck. I may go this route, though, especially because the hole would be where I want it.
Old 09-06-2010, 11:16 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
If you come into the cab soon (back seat area) then you'll have to route around teh cab (door sills or headliner). If you route under the truck and around to the firewall (as suggested) you'll be under the dash and closer to the CB.
Be sure to post pics of your antenna mounts. That's the same location I've decided upon when/if I put a radio in mine. I don't like drilling holes if I can help it either!
Old 09-06-2010, 09:34 PM
Studbuster's Avatar
Studbuster Studbuster is offline
Vehicle: '09 RAM 1500 4dr
Color: Light Graystone Pearl
Rep:61
Studbuster will become famous soon enough
I look at it this way; it's my truck, I'll own it for 5 or so years, I want it the way I want it, I'm not trying to keep it "new" for someone else, it's MY truck. Do what you want but do it right, it,s your truck. My CB antenna is in a 3/4" hole in the center of the roof! (check inside first for ribs)
It's my truck and I want it the way I want it!
IF YOU DON'T HAVE TIME TO DO IT RIGHT, WHEN WILL YOU FIND TIME TO DO IT OVER??
Dave
Old 09-08-2010, 10:10 PM
DIVERMAN's Avatar
DIVERMAN DIVERMAN is offline
Vehicle: 2010 Ram 1500 4X4
Trim Level: SLT BigHorn
Color: Inferno Red/Tan
DIVERMAN is on a distinguished road
haven't looked on my truck yet. but, there should be a plastic mounting plate on the fire wall by the steering wheel where the clutch would mount. should be able the drill a 3/4" hole through it and run the coax (with the end on it) through it. done it on all of my trucks so far, just haven't gotten to it on this one. lol.
2010 Ram 1500 4X4 CC SLT BigHorn 5.7L 3.55 Gears INFERNO RED, NAV/ALPINE,5" StepBars,Dual Exhaust.
Old 09-08-2010, 11:45 PM
Wildcat's Avatar
Rep:166
I ended up drilling a hole where I needed it and used a PCV Valve grommet. I hadn't mentioned it yet, because I don't have the pics, and I didn't want to invoke the wrath of the pic monsters, of which I have been one.
Old 09-08-2010, 11:56 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
Pic monsters? What pic monsters? Just means the mod didn't happen if there's no pics.
Brian:
