Old 09-09-2010, 12:56 AM
Rep:4072
LOL, ok, I do want to see it, though!
Old 09-09-2010, 02:19 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
Originally Posted by RootBeer View Post
Pic monsters? What pic monsters? Just means the mod didn't happen if there's no pics.
I know, and since i don't have pics to back it up i wasn't gonna mention it. I will try to get them up tonight.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 09-09-2010, 02:42 PM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Pic Monsters? What RB said are my mirrored comments also. LOL
Old 09-09-2010, 04:57 PM
Rep:2616
I bit the bullet & took my Ram to my audio/alarm guy, he works on hot rods, new vehicles, party boats, & motor cycles.
I left it with him & picked it up 2 days later.
He mounted the CB radio in the floor console & he installed a auxiliary cooling fan below it to help keep the radios heat sinks cooler. Note the little pocket to the left of the Rams stock radio.
he had to pull the headliner partially down, he did this for 2 reasons, mainly to drill the hole for the antenna, i had asked him to center it in the roof, but, there is a large center brace at that location, he drilled the hole directly behind it
He then cut out an area at the sloping part at the rear of the overhead console, he took an external cb speaker apart, getting rid of the box & used the speaker itself to install inside of the cut out console, he had to pull off some of the foam backing that is on the hidden side of the head liner, it is completely hidden & there is no sound distortion
he found a place to run the wiring through the firewall & then under the cab, my CB has to be wired to the main power source, in other words, the battery using heavy gauge wiring & protected by a fuse.
Then because i have to have 2 power lines going to the bed, 1 for my rotating lights & the other for my 30 gallon auxiliary gas tanks pump, he installed 2 switches that are controlled by switches in the Rams dash, just to the left of the Rams radio
You can see that the rotating lights wiring is run through the sign rack for the lights
the forward box is the 30 gallon auxiliary gas tank & the rear box holds all the tools that i use in my business
Old 09-09-2010, 05:04 PM
Rep:4072
I always did like your setup GT. Guess I got spoiled with my Jeep, I just ran the antenna through the liftgate and had the wire to where I could close the liftgate without pinching the wire, no drilling required, but I might just end up going that route and having someone professionally install it in my truck.
