Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Advanced Automotive Concepts - AACstyle - Dodge Ram Accessories!
Advanced Automotive Concepts - AACstyle - Dodge Ram Accessories! Advanced Lighting Solutions for High-End Vehicles! - Dodge Ram Accessories - Dodge Ram Parts!
Old 09-06-2010, 01:55 AM
DADS RAM's Avatar
DADS RAM DADS RAM is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Color: Go ManGo
Rep:124
DADS RAM will become famous soon enoughDADS RAM will become famous soon enough
Default AAC Does it Again "Dads Ram Style"
So with a lot of help from Johnathon at AAC we ordered our one of a kind, First ever, AAC Full Halos for a 05 Dodge Ram Daytona.
My Son "SCHIMBO" did all the install and work for me.
Mods are as follows.
AAC Frull Halos
Black Grill
Custom Painted Halos
Custom Painted Headlight Housing
AAC Flush Switch
Heres my Step by Step Install.
First Remove the Headlight by using a Star Bit, There are 3 total. 2 on the side nearest the engine then one under the light on the outside side.
Then place your headlight in the Oven on the center rack. Put the heat at 215 and set the timer for 12 minutes.When the timer goes off grab your oven mitts and take it out. Use a Flat Head screw Driver to pry apart the lens from the black housing. Carefull not to get an glue inside the light. once it is separated then you can start the install.
First Test fit the Halos and mark where the wires need to go through the housing. Then drill a small hole and feed the wires. Using th 3M tape on the back of the halos to adhere them to the light.
Once you have them on then its back into the oven for the same time and heat. once you take them back out you need to clamp the light. make sure its fully snapped back together with the tabs and the corners are tight.
Finally reinstall them in the truck and run the wires and BOOM . Time to turn heads.
Now for the Customizing part. I had the Housing painted black and the Halos painted Go ManGo. Once the Halos are painted you must get the paint off the leds. Some people reccomend wet sand paper but in fear of dulling the LEDS i used my finger nail and went one by one. They came out perfect. But it takes FOREVER.
Old 09-06-2010, 01:56 AM
DADS RAM's Avatar
Trim Level: Daytona
Color: Go ManGo
Rep:124
Finally I had the Grill painted Black. All the Chrome was just too much.
DADS RAM's Avatar
Trim Level: Daytona
Color: Go ManGo
Rep:124
heres some before
now on to the Nice Pics...
Old 09-06-2010, 01:57 AM
DADS RAM's Avatar
Trim Level: Daytona
Color: Go ManGo
Rep:124
Old 09-06-2010, 02:34 AM
MADDOG MADDOG is offline
Rep:22
That's a nice set of mods and some great pics!!!
Old 09-06-2010, 07:53 AM
DADS RAM's Avatar
Trim Level: Daytona
Color: Go ManGo
Rep:124
thanks ! we have the fog halos but they are not installed yet
Old 09-06-2010, 08:31 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
That looks really cool. Nice job and great install. The night pics are cool.
Old 09-06-2010, 01:08 PM
Justin@AACstyle.com's Avatar
Justin@AACstyle.com Justin@AACstyle.com is offline
Vehicle: 2500 MEGA-CAB
Color: errr...custom
Rep:114
Justin@AACstyle.com will become famous soon enoughJustin@AACstyle.com will become famous soon enough
Bad AZZ!
Let us know if we can assist again in the future
-Justin
For ALL of your RAM Lighting Needs!
1(800)407-5776
www.AACstyle.com
Old 09-06-2010, 01:39 PM
I push the skinny pedal
Rep:3277
Very nice! I was wondering if you'd installed the fogs, and those are some great shots next to the daytona charger
Kurtis
Old 09-06-2010, 01:42 PM
drivehard27's Avatar
drivehard27 drivehard27 is offline
Vehicle: 2012 dodge ram
Trim Level: sport
Rep:108
drivehard27 will become famous soon enoughdrivehard27 will become famous soon enough
Send a message via Yahoo to drivehard27
that looks really great and thanks for posting all the info
2012 ram sport qc
