Old 09-06-2010, 01:53 AM
YamiCaru's Avatar
YamiCaru YamiCaru is offline
Vehicle: 2010 Dodge Ram 1500 Quad Cab
YamiCaru is on a distinguished road
Thumbs down BS Lag with the Tire Pressure light and HIDs!!
Hey ya'll!
So i have a 2010 Ram that has the separate highbeams and lowbeams.
So i just put an HID kit on it and the damn tire pressure light keeps turning on!
I noticed that it turned on everytime that the headlights flickered, i installed a capacitor to end the flickering...it worked, but now there's a very odd problem at hand.
The tire pressure monitor crapped out!
the little yellow light remains on constantly and it's not reading the two back tires.
The light turns on when i turn on my HIDs....I just dont see the connection between lights and tires....
Does anyone out there have any clue as to WTF to do?!
This is really bugging me!
Just a few mins ago, the dash had a message: Service tire presssure monitoring system.
Any clue???
Why must Dodge make it so complicated to have HID lights?!
Old 09-06-2010, 07:46 AM
Rep:1885
The HID's are interfering with the TPMS because of RFI. Try moving your HID ballasts.
Old 09-06-2010, 09:28 AM
agjames agjames is offline
Vehicle: 2010 , crew cab, 1500
Color: inferno red
agjames is on a distinguished road
Also try some RF chokes on the wires. these are the square blocks you find attached on the outside of cables that come with computer equipment. they can be purchased separately as some electronic stores.
Old 09-06-2010, 10:55 AM
YamiCaru's Avatar
Kk, ill try moving the ballast first...
If i get some of these Chokes, where do i put them--on the HID wiring?
On the ballast or where exactly???
Old 09-06-2010, 01:04 PM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
The chokes are your best bet to remove the interference, you install them on the larger guage wire(s) running TO the ballast.
Kurtis
Old 09-06-2010, 07:49 PM
YamiCaru's Avatar
okay so i moved the ballast and im still getting the BS Lag issue with the tire pressure monitor.
How much are these Chokes and where can i get them??
are they hard to put on??? (any hard wiring needed??)
Old 09-06-2010, 08:00 PM
YamiCaru's Avatar
Gawd this is some major Lag....
I thought getting a 2010 Ram with the separate High and Low beams would make HIDs much easier than my 2007's H13 headlight...Grrrr..
Damn these damned complicated electrical systems!!!
ANywho, yeah so how do i do the choke deal??
Old 09-17-2010, 12:38 AM
BrentCRX BrentCRX is offline
Vehicle: 2010 Ram
BrentCRX is on a distinguished road
I also have a 2010 , 1st thing I did was HID Headlights and Fogs.
I had the same TPMS problem. Assuming it was a botched install I look in too what the Shop had done. I removed the Headlight kit , now all is well. When the HID fogs come on instant failure of the TPMS.
It is the interference with th ballast. Or so I have assumed. I tried to shield them , to no avail. Since you also are losing the rear TPMS just like me I am thinking there is a larger problem than RF like we think.
This is too much BS for a truck that is still on paper plates.
hid lights, hid problem, tire pressure monitor
