Old 09-06-2010, 04:43 PM
rancherman's Avatar
rancherman rancherman is offline
Vehicle: My DD is '97 Dodge Ram 1500
Rep:171
rancherman has a spectacular aura aboutrancherman has a spectacular aura about
Default one more 'ta-daa' !!
got the last headlite done and installed today. Here is how it played out.
I used the 3-M headlight restoration kit. I had to supply the household drill. After getting the units out and scrubbed clean of 'foreign bodies', I headed to the basement.
Before:
after stage 1 sanding disk. once you start, there's no turning back!
after stage 2: I just held unit between legs as a 'clamp' while sanding. Just light pressure is required, and a back and forth pattern. take a little care around the alignment 'tits'.
stage 3. this process is a damp foam rubber type disk. keep wet. and be very careful around the alignment tits, and the corners! LOOKING almost new now!
Ta-Daa!! the finished product, 3-M recommends a 'finish protectant' after this step....to prolong your work. It's a UV protectant, for yellowing. Supposed to wipe on, wipe off immediately. It doesnt come with the kit.
I would say if all mounting lugs are in good shape, no major cracks, this is a great product. If they have any flaws....then I would say replacement is the way to go.
I will admit, I knew there was a crack in the one side. This was more of an experiment for me. I will assure you there are absolutely NO swirl marks whatsoever. with removal and installation, figure a strong hour for completion. Cost $22 for the kit. (plenty of product for 2 lites.)
Old 09-06-2010, 04:45 PM
ScatPak07's Avatar
Rep:970
Great job man! Those look like new again! great write up as well
Rep:1625
Looks great! Awesome job!!
Old 09-06-2010, 04:55 PM
Those turned out good. Nice job!
Old 09-06-2010, 04:58 PM
rancherman's Avatar
Rep:171
Thanks guys! And thanks to Ramtech to leading me to this product!
I was skeptical at first... plastics are such a grey science. Now I am looking around to see what I can 'restore' next!!
Old 09-06-2010, 05:46 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Wow those came out great, nice job.
Old 09-06-2010, 06:29 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
That's an amazing turn-around. Great write up and the pics really make the point.
Brian:
Old 09-07-2010, 10:51 AM
Rep:4072
Very nice job on that man, they look brand new! Thanks for the write up and pics!
Old 09-08-2010, 10:09 AM
iRESQu iRESQu is offline
Rep:2217
Those are unbelievable! Holy cow, they look brand spankin' new! Great job, Youngin'! Reps to you when I can!
Old 09-08-2010, 12:57 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
oooh that stuff works good
