Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Place your Ad Here!
Old 09-07-2010, 12:31 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Default Blacking Out your stock 20's: Basic How Too!
I did this mod about 2 1/2 months ago and had a few people wanting a how too. So here you go.
Ok so basically your going to need to decide how you want to paint these. Whether or not you want to just paint the outer most part of the rim or the whole thing, in which case i would remove the tires. I just painted the outer most part. No removal of the tires needed.
Supplies....This is what you need minimum! 1 or 2 cans extra wont hurt. I mean you dont want to need one and not have it. So if you can paint like a pro then the amount listed should be enough.
1. 2 foam 120 grit sanding pads.
2. 1 bucket of water/water hose
3. 3 cans of Duplicolour Primer
4. 4-5 cans Duplicolour Chrysler Brilliant Black
5. 4-5 cans Duplicolour Clear Coat
6. 1 roll of 3M masking tape like 2 inch's wide .
7. Plastic Trash Bags (To tape off the rims)
8. Jack/Jack stands, ( I used four stands)
9. Tools to remove the lugs.
Step 1. Of coarse remove the wheels. Clean the rims as good as you can to remove all the oil, grit, and grime.
Step 2. Sand till you cant really see your reflection, should be like a brushed aluminum look. Use lots of water here, the key is to keep the foam pad wet.
Step 3. Clean again to remove any oil and shavings from the sand that got back on the wheel. Then just let them dry.
Step 4. Once dry you can start taping off the rim, you want to get tape between the rim of the wheel and the tire. Then slip your gigantic trash bag over the wheel. And cut out enough to let you re-tape to the tape that you put down previously.
Step 5. Double check the tape for gaps, once you feel comfortable start your primer coat. I only did one. NO Sanding is need and if you are that picky then dang.
Step 6. Let the coat dry for like 35 - 40 minutes minimum, that's pretty standard. Then go ahead and shoot the first Black Paint coat. Let it dry then paint the next. Let it dry then paint then next. Let it dry.
Step 7. Clear coat time! Same... Paint, Let it dry, Paint, Let it dry, Paint, Let it dry. Once it's dry pull the garbage bag off and re-use it on the rest. Then remove the original tape around the rim to finish it off.
Step 8. Almost done! At this point you got to give the clear coat time to settle. This could take around 3-4 hrs respectively you will see the change in texture don't worry just give it time. Once you feel comfortable put the suckers back on and your good to go.
http://www.ramforumz.com/showthread.php?t=55048 to see the pics!
This is pretty much exactly what i did to my rims so there yah go my first Z how too!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 09-07-2010, 12:38 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
nice write up! thanks
DODGE the father RAM the daughter!
Old 09-07-2010, 01:13 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
got before and after pics? no pics, it didn't happen.
Brian:
Old 09-07-2010, 12:49 PM
Rep:1625
Nice writeup!!
Old 09-07-2010, 08:27 PM
Big Daddy's Avatar
Big Daddy Big Daddy is offline
Vehicle: 2009 Crew Cab / 3.92 rear end
Trim Level: SLT Big Horn
Color: Stone White
Rep:917
Big Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to beholdBig Daddy is a splendid one to behold
Nice write up. You've given me the courage to go for it on mine in the next few weeks. Gonna try a different color but that's the neat about painting, if you want to try a different color go for it - if that doesn't work for you change it.
Big Daddy
Marching to Mamasita's beat for a real real long time...
____________________
Dennis
Old 09-07-2010, 08:33 PM
ScatPak07's Avatar
Rep:970
Thats a great write up man! Thanks for helping the members on here out!
Old 09-08-2010, 02:30 PM
Rep:4253
Very nice write up, thanks for taking the time to post that!
Old 09-08-2010, 02:37 PM
txhemi's Avatar
txhemi txhemi is offline
Vehicle: 2008 Quad Cab 1500 2WD
Trim Level: SLT Lone Star
Color: Mineral Gray
Rep:268
txhemi is a jewel in the roughtxhemi is a jewel in the roughtxhemi is a jewel in the rough
Great how-to!
Old 01-12-2011, 12:05 PM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
hey is this possible to do at a powder coater
i love your rims but is the finish going to stay on
Old 01-12-2011, 12:30 PM
five0addiction's Avatar
five0addiction five0addiction is offline
Vehicle: 2011 dodge ram slt
Color: bright white
Rep:306
five0addiction is a jewel in the roughfive0addiction is a jewel in the roughfive0addiction is a jewel in the roughfive0addiction is a jewel in the rough
nice write up
MARTIN...THE YOUNG GUN
