Dodge Ram Decals
Old 09-07-2010, 03:50 AM
armyrgr's Avatar
armyrgr armyrgr is offline
Vehicle: 2012 Power Wagon
Trim Level: Power Wagon
Color: Grey
armyrgr is on a distinguished road
Default Warped Rotors???
hey everyone, i recently just got from a year deployment in Iraq. Had my ol' lady drive the truck to and from her work once a week and sometimes on the weekend. Anyway, So dodge tells me my rotors are warped after I complain about a rotating vibration that I could feel in the pedals. So of course I have them re-surface them. Now, at light braking theres a clicking noise thats pretty loud coming from the left front. Of course when I took it back to them, and they test drove it, it didn't make the noise. All they did was take wheel off, look around and then put it back on. So I figured it was good to go. But no, very next day, its clicking again. WTF??? Any ideas?
Old 09-07-2010, 05:12 AM
UltraFlame's Avatar
Vehicle: 2007 Dodge Ram Quad
Rep:840
Might be a rock in the tire. I don't know of anything in brake systems that would cause a clicking. May just want to pull the tire and rotor and put it back on and see if it happens again. Inspect it while you have it all off. Good luck, let us know what you figure it out to be.
Old 09-07-2010, 07:49 AM
iRESQu iRESQu is offline
Rep:2217
Welcome back! Thanks for your service! As for your clicking, I don't know, so I would stick around for more advice.
Old 09-07-2010, 08:12 AM
Resident Technician
Rep:1915
If the surface of the rotor wasnt refinished smoothly enough, it could be causing noise.
Old 09-07-2010, 09:53 AM
armyrgr's Avatar
Color: Grey
ramtech, thats what i was thinking. it def isn't a rock in the tire though. thats the first thing i checked even tho you can tell from the sound that it isn't a rock in the tire. it makes a clicking/ tapping noise when applying light pressure to the brakes.
Old 09-07-2010, 09:08 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
You might want to make sure that the bolts holding your calipers on are tightened all the way. They would have to take them off to resurface the rotors, and maybe they didn't get them torqued down tight and they are a little loose.
I have seen this before on cars.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 09-07-2010, 10:50 PM
A loose or shifting brake pad .
Old 09-07-2010, 11:20 PM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
sounds like pad chatter to me.
Brian:
Old 09-08-2010, 12:47 AM
Hustleman Hustleman is offline
Vehicle: 2010 Dodge Ram 1500 Crew 2WD
Trim Level: SLT (Lonestar)
Color: Austin Tan
Hustleman is on a distinguished road
Sounds like the anti-rattle clips. They probably reused the old ones.
Old 09-08-2010, 12:58 AM
BRWinPortland BRWinPortland is offline
Vehicle: 2002 Dodge Ram 1500 4WD
Color: Green Pearl
BRWinPortland is on a distinguished road
Default warped rotors
definately sounds like anti rattle clips were left off
